Thread: LS6 Valve Springs?
Results 1 to 14 of 14
  1. #1 LS6 Valve Springs?
    Dec 2008
    indiana
    i can get a set of LS6 valve springs with the seals for cheap and i was wondering if they would benefit me. i have 145k miles on the motor so im not sure if the springs will be too strong and cause a lifter to collapse or do any other harm. should i buy some? i have the motor out of the car already and taken apart so i figured this would be a good time to change them. suggestions? thanks
  2. #2 Re: LS6 Valve Springs?
    Barksdale AFB, LA
    Do you have a cam or rockers? If not, there's no need.
    2009 Subaru Impreza WRX STI
  3. #3 Re: LS6 Valve Springs?
    Dec 2008
    indiana
    Quote Originally Posted by Sabrewings View Post
    no. the valvetrain is all stock. so yeah i think im gonna hold off on them. i just had to get another opinion on what people would do. thanks
  4. #4 Re: LS6 Valve Springs?
    Jersey
    Quote Originally Posted by projectGTP View Post
    Do you have 1.9 rockers? or minor cam?
    16' wrx sti- stock
  5. #5 Re: LS6 Valve Springs?
    Jersey
    lol sabrewings same time post same response
    16' wrx sti- stock
  6. #6 Re: LS6 Valve Springs?
    Barksdale AFB, LA
    Quote Originally Posted by 99prixgt View Post
    On other forums they know me by "lightning fingers".
  7. #7 Re: LS6 Valve Springs?
    Jersey
    Quote Originally Posted by sabrewings View Post
    on other forums they know me by "lightning fingers".
  8. #8 Re: LS6 Valve Springs?
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Not only is there no need if you don't have high ratio rockers or an aftermarket cam, it would do more harm than good as it would cause a lot more wear on what I'm sure is an already well worn timing chain tensioner.
    2001 Buick Regal LS - Almost Stock
  9. #9 Re: LS6 Valve Springs?
    Dec 2008
    indiana
    Quote Originally Posted by Scimmia View Post
    yeah thats what i was thinking. the timing chain tensoner isnt too wore out, but u can see the spot where its worn down. chain is still tight tho. all my valvetrain is stock so i think im not gonna buy them. the guy wanted 75 bucks with the seals and retainers
  10. #10 Re: LS6 Valve Springs?
    Barksdale AFB, LA
    If you want to replace your springs if you think they're getting old, I've got a set of 3800 springs with 80k miles on them right here. They'll be for sale in a couple weeks (probably just for shipping).
  11. #11 Re: LS6 Valve Springs?
    Dec 2008
    indiana
    oh alright. well let me know
  12. #12 Re: LS6 Valve Springs?
    GT Level Member DWosik13's Avatar
    Detriot,MI
    so with a mild aftermarket cam what benefits would they have?
    2002 BLACK GTP ... R.I.P.
    New Car 2009 Cobalt SS
    http://www.cardomain.com/ride/3352208
  13. #13 Re: LS6 Valve Springs?
    QCA, IA
    They'll eliminate valve float and let you shift higher to take better advantage of the cam. I believe that even a mild cam is really over the max lift of the stock valve springs, although I don't have the numbers to back that up.
  14. #14 Re: LS6 Valve Springs?
    Detriot,MI
    ok so im trying to look into it but i cant find a write up on spring replacement i tried searching couldnt find it lol
  1. Valve springs (L76 specifically)
    By Sabrewings in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-08-2009, 01:13 PM
  2. Autozone Valve Springs
    By 98GT3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-21-2009, 09:47 PM
  3. 90# valve springs on '97 heads
    By DanGTP in forum General Tech Discussion
    Last Post: 08-11-2008, 01:32 AM
