Thread: oil overfull again
Results 21 to 40 of 60
  1. #21 Re: oil overfull again
    Banned
    Mansfield, Ohio
    Quote Originally Posted by shawn3091 View Post
    i had a problem before with my oil being overfull and smelling like gas, i checked injectors and none are leaking, vacuum line to fpr was cracked, figured that fixed it but it did it again, big surprise. wth could the problem be? im getting real sick of it.
    If you have gas in your oil that's not good. Could mean bent valve, valve not touching the seat therefore constant fuel not being burnt. Eventually you washt the cylinder walls and your block needs bored and honed.
  2. #22 Re: oil overfull again
    GT Level Member shawn3091's Avatar
    Jan 2009
    State College PA
    i dont think it would be that, but i will find out when i put new mls gaskets in. id still like to know if the egr sticking could have done it, probably not but i dont know. and also more on the fuel getting pulled thru the carbon canister?
  3. #23 Re: oil overfull again
    Jan 2009
    State College PA
    talked to a tech at work and he said with that evap flow during non purge code i should try new evap purge solenoid and valve and see if the code stays off, said that it could very well cause it. parts from gm will be here saturday
  4. #24 Re: oil overfull again
    Jan 2009
    State College PA
    put new valve and solenoid on and now that code is gone and staying off so now the only code left is the mil control circuit malfunction? where should i even start?
  5. #25 Re: oil overfull again
    Banned
    Mansfield, Ohio
    You should start by selling me your hood
    I would just pay the 49.99 or whatever it is and have the dealers computer read it. At least you would know or have a general idea of where to start then.
  6. #26 Re: oil overfull again
    Jan 2009
    State College PA
    family shop has a snap on scanner that will read everything, mil control circuit manlfunction is the only code on it now, how to go about fixing it i dont know, i have saw all kinds of different things on the internet about it, could be cluster, or wire rubbed thru on harness or bad pcm. and i also work at a dealer, so this will get figured out one way or another
  7. #27 Re: oil overfull again
    Jan 2009
    State College PA
    and the hood goes nowhere lol
  8. #28 Re: oil overfull again
    Jan 2009
    State College PA
    there are now no codes, all is good there, but its still getting gas in the oil??? decided to pull the vac line off the regulator again today, i couldnt get it to leak but if i smell the vac line it smells like gas, so i guess im going to try changing the regulator and see if it helps.
  9. #29 Re: oil overfull again
    Jan 2009
    State College PA
    changed regulator, changed oil and about 50 mile and its overfull again
  10. #30 Re: oil overfull again
    im sorry, if you're getting gas in the oil, leaky injector?
  11. #31 Re: oil overfull again
    Apr 2009
    stockton ca
    have you tried taking it to a mechanic even if just to diagnose
  12. #32 Re: oil overfull again
    Banned
    Mansfield, Ohio
    I'm saying bent valve, valve not touching the seat, fuel not being burnt and dumped straight into your oil pan. I've had this happen before on a engine I built. It put down 193 with 8 bent intake valves and ran fine.
  13. #33 Re: oil overfull again
    Quote Originally Posted by cleangtp View Post
    I don't think anything with 8 bent valves runs fine
  14. #34 Re: oil overfull again
    New Jersey
    ditto
  15. #35 Re: oil overfull again
    Banned
    Mansfield, Ohio
    You don't think so, here's your proof guy! All motor build build 8 bent intake valves. Hear the miss down low, drove just fine. 193hp to wheels with mostly solid fuel in my oil, pulled engine, dropped arias 9.2 to 1 pistons in and went turbo now 450hp
    http://www.streetfire.net/video/5th-...rnals_6295.htm
    http://www.youtube.com/watch?v=-8SQLTHWD8Y 452whp, c16
    Really blue you should step off my nutz. I'm bout sick of you following me like you have no friends!
  16. #36 Re: oil overfull again
    can i drive that car? 452 fwhp has got to be an absolute beast in that prelude...
  17. #37 Re: oil overfull again
    Banned
    Mansfield, Ohio
    I don't think it's the best car, and I don't act like every other Honda owner. Was it good for the car on the dyno, hell no, did I know they were bent nope. Did Golden Eagle install the pistons with the exhaust valve reliefs on the intake side of the head yep!
  18. #38 Re: oil overfull again
    New Jersey
    Eh, I own a 06 Saturn vue with a Honda engine\trans in it. Does this make me a "Honda owner" or does that not count
    BTW. We're getting off topic. What was the original problem? the engines oil level went UP? oil very often smells like carbon\gas due to blowby and what not.
    is the oil clean and cosmetically ok other then smell?
  19. #39 Re: oil overfull again
    Banned
    Mansfield, Ohio
    Quote Originally Posted by MrTube View Post
    We were on topic until blue came in here calling me a liar. I was just going to the extreme trying to help fix the oil full issue. Valve float is very possible however if this has been ruled out I'm sorry.
  20. #40 Re: oil overfull again
    with these cars it seems more likely that a leaky injector would be the issue versus valve float.
  1. oil is overfull and smells like gas???
    By shawn3091 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2010, 02:58 PM
