Thread: oil overfull again
Results 1 to 20 of 60
  1. #1 Re: oil overfull again
    GT Level Member shawn3091's Avatar
    Jan 2009
    State College PA
    talked to a tech at work and he said with that evap flow during non purge code i should try new evap purge solenoid and valve and see if the code stays off, said that it could very well cause it. parts from gm will be here saturday
  2. #2 Re: oil overfull again
    Jan 2009
    State College PA
    put new valve and solenoid on and now that code is gone and staying off so now the only code left is the mil control circuit malfunction? where should i even start?
  3. #3 Re: oil overfull again
    Banned
    Mansfield, Ohio
    Quote Originally Posted by shawn3091 View Post
    You should start by selling me your hood
    I would just pay the 49.99 or whatever it is and have the dealers computer read it. At least you would know or have a general idea of where to start then.
  4. #4 Re: oil overfull again
    Jan 2009
    State College PA
    family shop has a snap on scanner that will read everything, mil control circuit manlfunction is the only code on it now, how to go about fixing it i dont know, i have saw all kinds of different things on the internet about it, could be cluster, or wire rubbed thru on harness or bad pcm. and i also work at a dealer, so this will get figured out one way or another
  5. #5 Re: oil overfull again
    Jan 2009
    State College PA
    and the hood goes nowhere lol
  6. #6 Re: oil overfull again
    Jan 2009
    State College PA
    there are now no codes, all is good there, but its still getting gas in the oil??? decided to pull the vac line off the regulator again today, i couldnt get it to leak but if i smell the vac line it smells like gas, so i guess im going to try changing the regulator and see if it helps.
  7. #7 Re: oil overfull again
    Jan 2009
    State College PA
    changed regulator, changed oil and about 50 mile and its overfull again
  1. oil is overfull and smells like gas???
    By shawn3091 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2010, 02:58 PM
