Thread: 1.9 Modified Rocker Install
Results 1 to 20 of 37
  1. #1 1.9 Modified Rocker Install
    GT Level Member kissmyss's Avatar
    Jan 2009
    ny
    The parts are coming in;
    05 SS CAI intake, Front & rear STB's, ZZP SS DP wcat, ZZP 180 t-stat, ZZP 3.5 tensioner pulley (both), ZZP S/S ceramic plog with ceramic crossover, Overkill Pcm, Aeroforce triple gauge w/pillar pod, Thrasher 3.4 s/c pulley, MCR 200 amp alternator, PRJ wires, Intense Shift kit, ZZP 1.9 modded rockers, ZZP stage 2 Tb, Extreme Dimensions rear bumper lip.
  2. #2 Re: 1.9 Modified Rocker Install
    wow, thats an expensive spring compressor. you can make one with a notched metal plate and one of the rocker bolts. about $2 in pieces parts. either way, good luck.
  3. #3 Re: 1.9 Modified Rocker Install
    Jan 2009
    ny
    Not really, Ebay is your friend and the local AZ sells them. This product comes with a lifetime warranty, in case of failure all I have to do is take it to AZ for replacement.
  4. #4 Re: 1.9 Modified Rocker Install
    Jersey
    link to spring compressor? i need one
    16' wrx sti- stock
  5. #5 Re: 1.9 Modified Rocker Install
    Jan 2009
    ny
    Quote Originally Posted by 99prixgt View Post
    I got it off ebay, the starting bid was $9.99 and I was the only one who placed one. Here ya go;http://cgi.ebay.com/ebaymotors/OEM-2...motiveQ5fTools
  6. #6 Re: 1.9 Modified Rocker Install
    Jan 2009
    ny
    The preparation continues;
    I tested the gauge for proper function and for any leaks using my air compressor. Everything checks out ok, I'll be placing my order with ZZP after I take care of another issue with the car.
  7. #7 Re: 1.9 Modified Rocker Install
    Jan 2009
    ny
    Finished the spring install, gaining access to the rear was more work than I expected. I ran into a few issues, broke the original spring compressor, after the first use and had to rent from Autozone. The compressor has a lifetime warranty and will be replaced. I also broke a rocker bolt while torquing it. The wrench never clicked letting me now I reach the proper torque setting, it happened after the front and the first three rears were done. When I remove the pedestal the bolt was sticking out of the head and I was able to remove it using my fingers. Now I have to order some new bolts and live with the fear of breaking another, this time inside the head. I have other wrenches, although I may rent one from Autozone. I didn't take many pictures since there are so many floating around on this procedure. I'll post my results and any other issue once the install is complete. This may be awhile, unless I can find some rocker bolts locally.
    No luck finding them locally and the places that could get them said they had to be ordered. AZ wanted $6.99 plus tax for (1) and $83.88 plus tax for (12). So I chose to order them myself and save about $60. They should be here by Tuesday, I'll probably want until the weekend to finish the job. hear are a few picks;
    Broken spring compressor
    AZ loaner spring compressor and broken rocker bolt
  8. #8 Re: 1.9 Modified Rocker Install
    YIKES! You broke that expensive ass thing AND a rocker bolt...lucky you didn't ruin the head breaking that bolt off
  9. #9 Re: 1.9 Modified Rocker Install
    Donating Users kfish's Avatar
    Ohio
    it helps a ton if you tap the top of each walve with a hammer before using the compressor...the oil varnishes up and half ass acts like a glue
  10. #10 Re: 1.9 Modified Rocker Install
    Jan 2009
    ny
    Quote Originally Posted by kfish View Post
    Thanks, the springs are done and they were pretty easy. That tool wasn't the right one for the job, the loaner was perfect. The right tools mean everything, now I'm just waiting on the replacement bolts. I was nervous about dropping a valve, not realizing a broken bolt stuck in the head is even worst. I only have to put the rear rockers on and button everything.
  11. #11 Re: 1.9 Modified Rocker Install
    Jan 2009
    ny
    The bolts came and I installed the rockers. I'm getting a tapping noise, it sounds like it's coming from the rear valve cover. I thought it would go away, when the oil circulated. I made sure all the bolts were torqued to specs, I'm going to check the oil level although it wasn't making noise before the install and remove the rear cover to check the rockers. Here's a video;
  12. #12 Re: 1.9 Modified Rocker Install
    Jan 2009
    ny
    I may have found the problem, some of the rockers have side to side play. My theory is the center piece is welded or attached to caps that roll across bearings when they turn(rock). The center piece isn't attached to the caps, which creates side play and they rock independent of the cap without involving the bearings. These two were installed in the rear, I haven't taken the front apart to see if has similar rockers. Here's a video to possibly show what I'm talking bout.
  13. #13 Re: 1.9 Modified Rocker Install
    Jan 2009
    ny
    I took the front apart and found some that were loose also. Here's a video;
    I'm waiting to hear from ZZP, I've never had a problem with them before and hopefully this can be resolved quickly.
  14. #14 Re: 1.9 Modified Rocker Install
    Yup, that's exactly what mine is doing right now. Good to know this should hopefully be an easy fix.
  15. #15 Re: 1.9 Modified Rocker Install
    GTP Level Member tazyboy28's Avatar
    home town
    wow, can't wait to tackle this project. so do u think its a problem with the type of rockers u have or just plain rockers in general.
    specs:2007 GP GT, wizair intake, ZZP headers, 3inch high flow cat downpipe. SLP power flo exhaust
  16. #16 Re: 1.9 Modified Rocker Install
    Quote Originally Posted by tazyboy28 View Post
    Type of rockers? Plain rockers?
    Those are stock modded rockers.
  17. #17 Re: 1.9 Modified Rocker Install
    home town
    yeah, aren't there different types?, like 1.9, 1.95, modified . . .etc
  18. #18 Re: 1.9 Modified Rocker Install
    The different number means the ratio.
    Modded are just stock rockers that are re-welded to have a higher ratio
    Rollers are lightweight rockers that are way easier on valvetrain parts...but you pay out the ying yang for them.
  19. #19 Re: 1.9 Modified Rocker Install
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    so is it not good to have that side to side play of the rocker? i just installed my 1.9 modded stockers that i bought used and have a tapping noise as well. Torqued the CC reusable rocker bolts to 25 ft lbs
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  20. #20 Re: 1.9 Modified Rocker Install
    SE Level Member Amb4's Avatar
    Nov 2009
    Canada
    yep just finished my install and the tapping noise is there.... Is this going to be normal for everyone? and is it safe to drive the car with the tapping noise there or what?
  1. write up on rocker install?
    By AmericanSoldier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2010, 08:07 PM
  2. 1.9 modified rocker installation
    By rolyat in forum General Tech Discussion
    Last Post: 01-26-2010, 12:54 AM
  3. Rocker install
    By mikesarebetter in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2010, 06:07 PM
  4. Total lift after rocker install.Question
    By TDCRacing in forum General Tech Discussion
    Last Post: 12-06-2008, 04:03 PM
  5. 1.9 modded rocker install
    By ExpyGator in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 12:38 PM
