Thread: 1.9 Modified Rocker Install
Results 1 to 20 of 37
  1. #1 Re: 1.9 Modified Rocker Install
    GT Level Member kissmyss's Avatar
    Jan 2009
    ny
    I may have found the problem, some of the rockers have side to side play. My theory is the center piece is welded or attached to caps that roll across bearings when they turn(rock). The center piece isn't attached to the caps, which creates side play and they rock independent of the cap without involving the bearings. These two were installed in the rear, I haven't taken the front apart to see if has similar rockers. Here's a video to possibly show what I'm talking bout.
    05 SS CAI intake, Front & rear STB's, ZZP SS DP wcat, ZZP 180 t-stat, ZZP 3.5 tensioner pulley (both), ZZP S/S ceramic plog with ceramic crossover, Overkill Pcm, Aeroforce triple gauge w/pillar pod, Thrasher 3.4 s/c pulley, MCR 200 amp alternator, PRJ wires, Intense Shift kit, ZZP 1.9 modded rockers, ZZP stage 2 Tb, Extreme Dimensions rear bumper lip.
  1. write up on rocker install?
    By AmericanSoldier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2010, 08:07 PM
  2. 1.9 modified rocker installation
    By rolyat in forum General Tech Discussion
    Last Post: 01-26-2010, 12:54 AM
  3. Rocker install
    By mikesarebetter in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2010, 06:07 PM
  4. Total lift after rocker install.Question
    By TDCRacing in forum General Tech Discussion
    Last Post: 12-06-2008, 04:03 PM
  5. 1.9 modded rocker install
    By ExpyGator in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 12:38 PM
