Thread: supercharger rattling at low rpm
Results 1 to 20 of 30
  1. #1 supercharger rattling at low rpm
    GTX Level Member Juanmiguel's Avatar
    Mexico
    Hey all. I have a 98 GTP and it makes a rattling sound when it's stopped and in gear. It doesn't make that noise when at higher RPM (1000+). At first we thought it was the steering pump that was causing this problem because the rattling increased when turning the wheel, but today we took off the supercharger belt and the rattling was gone.
    We did notice the SC pulley was a little loose when turned on either direction. Does anyone know if this might be a SC problem for sure? We did check the tension pulley spring and it was fine. I'm new to the L67 and have seen that the couplers get worn off and need replacement. Could this be the case?
    Thanks,
  2. #2 Re: supercharger rattling at low rpm
    SE Level Member almighty's Avatar
    northern illinois
    +1 for the coupler, if you search around there are a few writeup's with pictures showing how to replace it.
  3. #3 Re: supercharger rattling at low rpm
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    x2..agreed
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  4. #4 Re: supercharger rattling at low rpm
    GTX Level Member JoelW98GTP's Avatar
    Nov 2009
    Portsmouth, OH
    +3 on the supercharger coupler
    98 GTP - Autolite 104s, wires, 180* t-stat, fwi, catless dp and plog, glasspack res, Reptile tuned PCM, tinted tails.
    91 Toyota MR2 Turbo - 327RWHP 322RWTQ 11.48@122mph
    03 BMW 325i - tint. stock.
  5. #5 Re: supercharger rattling at low rpm
    Apr 2009
    stockton ca
    4x coupler
  6. #6 Re: supercharger rattling at low rpm
    swift current,sask.
    x5, problem solved!!
  7. #7 Re: supercharger rattling at low rpm
    Mexico
    jaja thanks guys, I'll ask tomorrow at the local autozone if they have the coupler and the supercharger oil, i bet it's never been changed before.
  8. #8 Re: supercharger rattling at low rpm
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    autozone probably wont have the coupler. Even GM says they cant get them, that you have to get a whole new blower haha. Best bet would be to order one off one of the vendors. I've had no problems with mine, and its a pretty simple install too
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  9. #9 Re: supercharger rattling at low rpm
    Mexico
    Quote Originally Posted by Rather B Blown View Post
    Yeah I know what you mean. I went today there and to another autoparts vendor and it was like if I was asking for alien technology when I mentioned a supercharger coupler. I could try GM or another specialized turbo and supercharger vendor here, but they mostly do trucks. I'll just order the oil and the coupler from ZZperformance.
  10. #10 Re: supercharger rattling at low rpm
    Topeka, KS
    Only place i know that you can get the coupler is from ZZP. Its a stupid easy fix too. I did mine in about an hour and a half when i was a novice mechanic. Also GM will not have this part at all. They will tell you that the Supercharger is not serviceable and it must be replaced or sent off to Eaton.
    ZZ Performance
    Mine made a horrible chattering noise when idleing before i replaced it.
    Here's the writeup i used to replace mine.
    http://www3.sympatico.ca/aepa/blowerinstall.html
  11. #11 Re: supercharger rattling at low rpm
    agreed. thats how i got a brand new blower! i love my warranty!
  12. #12 Re: supercharger rattling at low rpm
    SE Level Member vsl67's Avatar
    Australia
    Im going to hope everyone is right and it is the coupler but what you are describing is also the same as stuffed rotor bearings especially if its really loud at idle heres some videos of mine with the rattle before I replaced the rotor block bearings
    YouTube - Eaton M90 rattle
    YouTube - Eaton m90 supercharger rattle no 2
  13. #13 Re: supercharger rattling at low rpm
    Banned - Busted For Scamming
    Feb 2009
    You can get the coupler here for cheaper, $20 free shipping. I buy them here all the time and they ship quick.
    Eaton supercharger coupler M90 Thunderbird Etc S:eBay Motors (item 140369271486 end time Dec-29-09 10:26:27 PST)
  14. #14 Re: supercharger rattling at low rpm
    Mexico
    Quote Originally Posted by vsl67 View Post
    Im going to hope everyone is right and it is the coupler but what you are describing is also the same as stuffed rotor bearings especially if its really loud at idle heres some video of mine with before I replaced the rotor block bearings
    Thanks for your input, I think it's a little bit different in my case. It doesn't do it in neutral and when the RPM goes a bit higher, it goes away. I ordered the coupler and the oil from ZZP a few days back, but I don't expect to receive it until a couple more days due to the holidays and the distance. I'll find out once I put in the new coupler.
    Also just as a side note, I just did the dog bone flip thing on the engine and the rattling is less now, atleast 50%. It used to annoy me enough at the stoplights that I used to put it in neutral just to make it stop. Now is not loud enough to bother me.
    Does anyone know if there's another purpose or effect to flipping the dog bone mounts other than preventing the engine to move so much? I only did it for this reason, but was wondering if there was something else to it.
    I'll take a video of my rattling tomorrow and upload it too.
  15. #15 Re: supercharger rattling at low rpm
    GT Level Member tylerbinski's Avatar
    Canada
    LOL
    coupler x6
    you *could* just raise your idle with a tuner and it wont rattle..
    Thats what I did to the winter beater (regal) and its just fine..
    -like i said winter beater, so this prob isnt the best method for u
    '04 BLK GP - .. Turbo :P
    GTP SIC - '02GTP | XP Cam | Intercooled Turbo Kit | Cutout....Fire mod 9/11
    GTPSIC '02 | Twin charge, XP cam et
  16. #16 Re: supercharger rattling at low rpm
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    X7 coupler, and of course get new s/c oil. sounds like rocks in a tumbler.
  17. #17 Re: supercharger rattling at low rpm
    GT Level Member hourang's Avatar
    commerce, mi
    does anyone know if the zzp s/c oil is genuine GM s/c oil that's pre-measured or is it their own concoction?
    -Jeff
    98 GTP Black 4dr - fully loaded - short ram intake, tinted tails, hole in resonator.
    sold 98 camaro ss - 6spd fully loaded - cam, intake, exhaust, ford 9in rear 4.11s, 6point chromoly cage, tnt 150shot nitrous, nittos, etc.
  18. #18 Re: supercharger rattling at low rpm
    Charles City, IA
    Pretty sure its GMs. It is not pink like in their pic.
    SMGPFC Two Nipple General
  19. #19 Re: supercharger rattling at low rpm
    Dec 2008
    hueytown, alabama
    it;s fine to use. make sure u get the right quantity.
  20. #20 Re: supercharger rattling at low rpm
    Australia
    A lot of people in Aus including myself are using 75/80w gear oil for sometime now with out any dramas or oil loss because the GM oil is so exspensive
  1. rattling ass
    By 04muscle in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2009, 11:44 PM
  2. car rattling
    By jack08 in forum Audio, Security & Visual Electronics
    Last Post: 09-20-2009, 04:32 AM
  3. rattling in right rear?
    By runn141 in forum Brakes/Suspension/Chassis
    Last Post: 06-04-2009, 05:00 PM
  4. Dash Rattling
    By cboth686 in forum General Tech Discussion
    Last Post: 12-20-2008, 09:05 PM
  5. Rattling front end
    By macs2000gtp in forum Brakes/Suspension/Chassis
    Last Post: 08-28-2008, 04:40 PM
