Thread: Car Won't Start... Just Cranks.
Results 1 to 20 of 27
  1. #1 Car Won't Start... Just Cranks.
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    I have 2001 Grand Prix GT with an SS M90 Kit. I went to do a cold start yesterday, and the car wouldn't start. It just cranks. It will run if I keep my foot on the gas, but as soon as I let off, it dies. No code came up on my Aeroforce scan gauge. I have changed the fuel filter and spark plugs. Anyone have any ideas?
  2. #2 Re: Cat Won't Start... Just Cranks.
    clean your maf sensor maybe
  3. #3 Re: Cat Won't Start... Just Cranks.
    I'll try that. Do I have to use MAF sensor cleaner? I'm trying to get my car running right now and no shop is open.
  4. #4 Re: Cat Won't Start... Just Cranks.
    I'm gonna try electrical contact cleaner.
  5. #5 Re: Cat Won't Start... Just Cranks.
    Fixed!!! Thank you so much!!!
  6. #6 Re: Cat Won't Start... Just Cranks.
    no problem man. If it starts to do it agian, now you know what it may be, but next time that maf might go bad.
  7. #7 Re: Cat Won't Start... Just Cranks.
    Topeka, KS
    They actually do make a Maf Sensor Cleaner. Brake Cleaner works too if your in a bind. If that happens again unplug the maf. You car will run without it. It just puts it into speed density mode. It may not like to idle at first without some throttle. Trust me been here done this before lol.
  8. #8 Re: Cat Won't Start... Just Cranks.
    Quote Originally Posted by rynoman03 View Post
    NO...man.
    No.
    Never spray a sensor with brake clean...it'll eat it straight up and destroy it. Been there, done that.
    MAF/Sensor cleaner is a very diluted mixture of parts cleaner...so it is sensor safe.
  9. #9 Re: Cat Won't Start... Just Cranks.
    Topeka, KS
    NO...man.
    No.
    That's funny coulda swore Reptile told me I could use Brake Clean if needed. I guess I am mistaken.
  10. #10 Re: Cat Won't Start... Just Cranks.
    Pennsylvania
    Did you try swinging it around the carpet?
    Tutorial
  11. #11 Re: Cat Won't Start... Just Cranks.
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Wouldnt use brake cleaner on a maf.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  12. #12 Re: Cat Won't Start... Just Cranks.
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Yea i use the maf cleaner that comes in the red and white can.
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  13. #13 Re: Cat Won't Start... Just Cranks.
    Charles City, IA
    Yeah only use maf cleaner or electrical contact cleaner.
    SMGPFC Two Nipple General
  14. #14 Re: Cat Won't Start... Just Cranks.
    Nov 2008
    Waterloo, Iowa
    Did anyone else notice the title says his cat won't start?
    My $0.02, if your cat isn't starting, it's probably dead.
  15. #15 Re: Cat Won't Start... Just Cranks.
    Charles City, IA
    Did not even notice it.
  16. #16 Re: Cat Won't Start... Just Cranks.
    Bowie, MD
    lol
  17. #17 Re: Cat Won't Start... Just Cranks.
    I fail.
  18. #18 Re: Cat Won't Start... Just Cranks.
    Pretty much.
  19. #19 Re: Cat Won't Start... Just Cranks.
    Electrical contact cleaner worked for me.
  20. #20 Re: Cat Won't Start... Just Cranks.
    Nov 2008
    Waterloo, Iowa
    Feeding it, and a trip to the vet might help as well.
  1. Engine Cranks but Will not Start
    By rockytop104 in forum Introductions/Noob Questions
    Last Post: 10-04-2010, 08:21 PM
  2. car cranks but wont start unless you press accelerator
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2009, 10:49 PM
  3. cranks wont start
    By zach_gt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-19-2009, 08:10 PM
  4. Cranks over but will not start
    By wfj8251 in forum General Tech Discussion
    Last Post: 02-08-2009, 02:47 PM
  5. HELP! Cranks then Don't Crank
    By Bigboy49251 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-09-2009, 03:25 PM
