Thread: Engine Guru's, Help Me Understand Ignition Timing
Results 1 to 20 of 27
  1. #1 Re: Engine Guru's, Help Me Understand Ignition Timing
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    LOL. yeah, its just that easy.
    Even if it were, I would still like to try a few of the other ideas Ive ran across on some L32 heads and see if there is any merit to them. Plus it would get me comfortable in pulling an engine down to the heads which I have never done before.
    nevermind that custom heads such as those would likely be at least as much as you paid for your car, but hey, if you cant go big, go home
    its only money, right?
  2. #2 Re: Engine Guru's, Help Me Understand Ignition Timing
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    As far as better atomization goes do gas injectors even come close to the atomization of fuel compared to a diesel injector? We don't even come close the the fuel pressures of a diesel engine.
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  1. MSD Ignition Coils
    By GP2003GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-16-2008, 10:18 AM
  2. Ignition Problem.
    By dbean in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2008, 07:49 PM
  3. Key stuck in ignition-
    By checkm8gtp in forum General Tech Discussion
    Last Post: 02-21-2008, 07:46 PM
  4. Need More Help, Ignition
    By SyntheticShield in forum General Tech Discussion
    Last Post: 01-28-2008, 12:17 AM
