Thread: Drivability Problems
Results 1 to 18 of 18
  1. #1 Drivability Problems
    Killeen, TX
    Hey everyone....Ive been having this problem for the past 20,000 miles and I still can't figure it out...Ill be driving around time and when I give my 2004 GTP 1/2 throttle my RPM's will start to bounce and the car starts to shake because of it....took the tranny pan off and no big shavings or anything so I'm wondering if it has to do with the engine....any answers will be appreciated.
  2. #2 Re: Drivability Problems
    Charles City, IA
    Check for a misfire.
    SMGPFC Two Nipple General
  3. #3 Re: Drivability Problems
    Donating Users blowfishRus6's Avatar
    g.a.
    does it do it on hills or anytime you give it 1/2 throttle?? low rpms or all rpms??
    my car will start to jump rpms a little when going up hill in 4th and the torque converter is locked around 1200 rpms it will jump around a tad. but it does not shake anything. i just let off to relese the torque converter and it stops.
    my problem is my transmission, maybe the torque converter sliping.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  4. #4 Re: Drivability Problems
    GT Level Member 01gtspecial's Avatar
    Apr 2009
    Georgia
    sounds like a bad coil pack, or wire, or plug, or even the ignition control module. if you've driven it for 20k like that...you've probably scored a cylinder by now.
    start by checking for a bad wire or fouled up plugs, if they're all good then...
    take the packs off and check to see if the primary and secondary resistance is in spec, on EACH pack. advance auto parts can help you with that. they can also check to see if your ignition control module is bad.
    make sure you don't cross any wires when putting it all back together.
    you're probably getting bad gas milage too aren't you? how many miles on the car? any mods?
    01 GT special ed.: SD hood, GMPP kit, poly sway bushings, Eibachs/Gabriel Ultras, Eagle GTs, ZZP anti-pogo, ZZP short dogbones, ZZP poly trans, ZZP PCM, ZZP HV TB, ZZP HV3, P&P LIM, 4" FWI, 3" DP, custom exhaust, pwdr-coated Trans Am brakes, NGK iridiums, Mobil1 Syn fluids, stage 2 voltage booster, BIG 3, real loud stereo...
  5. #5 Re: Drivability Problems
    PA
    My guess is worn valve body in tranny. Mine did the same thing when I bought it. Between the DIY shift kit and tuning it with the PT, I don't have these issues anymore.
    Taken from here:
    Tach bounces up and down a few hundered rpm while cruising in lockup:
    Another common problem / concern of this transmission and more pronounced with added engine power or higher mileage. This generally happens when the valve body has excess wear in the TCC valve area. Excessive fluid leakage in this area of the valve body causes TCC apply pressure loss and can lead to uncontrollable TCC operation which causes the engine rpm to bounce up and down a bit. This problem is noticed most after driving a while and speeds between 42 and 70mph and in 4th gear. There are other causes to this problem that can be from worn or shrunken teflon seals on the input shaft, a bad o-ring on the input shaft that seals in the torque converter, a faulty torque converter clutch, and even a bad pressure control solenoid. Another common occurance is a worn out sleeve in the channel plate that supports the input shaft. When this sleeve wears the input shaft will get chewed up where the sealing rings are and cause problems. Commonly code P0741 will be found in the pcm memory as a stored code and is described as Torque Converter Clutch Stuck Off. When this happens adaptives shifts are disabled, TCC operation is disabled, and 4th gear can be disabled. Generally a new or reman / repaired valve body will correct this condition and a new EPC solenoid is always suggested as well. The TCC/PWM solenoid is rarely ever at fault and I am yet to find one bad. Again the valve body is the common cure BUT not always the culprit and certainly not the whole problem after this has been happening for a while. Any time a torque converter fails there will be debris going back into the trans. There is a pressure relief valve in the channel plate that will collect debris from a bad torque converter and reduce cooler flow, cause trans to run hot, and greatly effect TCC operation and can destroy a new converter in a matter of miles if this isnt carefully inspected or upgraded. The best way to verify proper operation as commanded by the pcm is with a scan tool by viewing TCC slippage rpm, TCC duty cycle, EPC data, and checking any codes and making sure the engine is running properly and a misfire is not a false sense of a torque converter problem or shudder.
    2001 GSE
  6. #6 Re: Drivability Problems
    Killeen, TX
    Hey everyone...thanks for some suggestions....i have checked for a misfire and all is good in the ignition department...about 5,000 miles ago I put 3 MSD ignition coil packs with 10.4 mm PRJ wires on it from 3800performance.com....i also have a K&N Short Ram Intake.....Custom Race Headers with High Flow Cat to a 2.5 " DynoMax Cat-Back....I have 96,000 miles on it with about 17 MPG in the city and like 22MPG on the highway...pretty much when its cold when going up hills at 40 + MPH with half throttle or sometimes a little less throttle the RPM's love to shake....also to get it to stop bouncing around I have to give it alot more throttle to power out of it so im clueless.... I dont wanna spend way too much at a shop for someone to give me some bull**** so if any of the new info helps then let me know....I appreciate it guys
  7. #7 Re: Drivability Problems
    Killeen, TX
    hey Zef_66...what do you mean by tuning it with the PT...power programmer....cant find one for a 2004 anywhere
  8. #8 Re: Drivability Problems
    g.a.
    i have a powrtuner for my 04. hptuners also works for 04-05s. raising my torque converter lockup speeds cured the majority of my problems.
    its slow.
  9. #9 Re: Drivability Problems
    Killeen, TX
    yeah thats what I have been trying to find but I'm nervous about getting the wrong one....could you let me know which one to buy and possibly the part number...ive been told stories that they wont work for the 04's. Appreciate it
  10. #10 Re: Drivability Problems
    g.a.
    for the powrtuner or hptuner??? the powrtuner is no longer sold. for hptuners just buy the gm suit. its 500$ tho. the only issuie is the 06 and newer grand prixs. with your 04 your fine.
    HPTuners.com >> Performance At Your Fingertips
    or just find someone with a tuner and have them tweak it some.
    its slow.
  11. #11 Re: Drivability Problems
    Apr 2009
    Georgia
    throttle position sensor maybe?
  12. #12 Re: Drivability Problems
    Killeen, TX
    For the HP Tuners VCM Suite, Do i need to get the standard version or do i need to get the pro version to be able to change my torque converter settings. No the TPS is still good
  13. #13 Re: Drivability Problems
    Killeen, TX
    Also for the power tuner that you have and isnt sold anymore...what is the brand and all that so maybe someone might be selling it on ebay or something??? Appreciate it
  14. #14 Re: Drivability Problems
    g.a.
    DHP powrtuner. i think there is one forsale for 300$ right now. its not as user friendly and there is not as much support for it. for the hptuner all the pro version is, is a place to hook up your wideband and data log that too. if you want that option go for it, but i dont really think you need it.
    its slow.
  15. #15 Re: Drivability Problems
    Wichita
    Quote Originally Posted by 01gtspecial View Post
    If it's the TPS sensor he'd continue to go the same speed even goin up a slope. & if shifting into or through reverse there would be an ugly clunking sound while shifting.
  16. #16 Re: Drivability Problems
    Quincy, Mass
    Quote Originally Posted by ArmyMech651 View Post
    take them off! the stock coil packs are better than the MSD ones.
    No more GP 04 Impala SS Indy:
  17. #17 Re: Drivability Problems
    g.a.
    depends. alot of people run msd's with no problem. but others have problems. its all in the wiring up from what i have gathered. but there is nothing wrong with the stockers.
    its slow.
  18. #18 Re: Drivability Problems
    Wichita
    The amount of spark a coil can produce is limited by computer. There wouldn't be any performance gains at all, unless you have bad coils.
  1. 07 gxp with nav mp3 problems
    By pjs29 in forum General Tech Discussion
    Last Post: 08-22-2009, 01:11 PM
  2. 3 last problems
    By indyal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-22-2009, 06:14 AM
  3. DIC problems
    By rookie in forum General Tech Discussion
    Last Post: 03-07-2009, 03:22 AM
  4. drivability "issue"
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2009, 08:11 PM
  5. some problems
    By EmEaston24 in forum General Tech Discussion
    Last Post: 09-23-2008, 06:28 PM
