Thread: few electrical problems
Results 1 to 6 of 6
  1. #1 few electrical problems
    Apr 2009
    stockton ca
    theres 3 or four wires front bottom of engine that can either be ground or the hot for the starter
    If they arent hot when bats hooked up and key is on should i assume they are grounds
    also are there 2 grounds on the trans and one main line to the starter with one small wire going to it aswell? will be at school in an hour or so and these are the final wire i need to hook up
    Any help would be great
  2. #2 Re: few electrical problems
    Quincy, Mass
    the starter has 3 wires, 2 small and one big, the big one has a hook on it so it sits in place. the 2 smaller wires have smaller eye holes and wont fit on the same spot as the big wire. the ones for the trans, i think are 3 wires on 2 eye holes if i remember right, but they are all the same size eye whole and i think are the engine grounds.
    the purple wire on the starter goes to the smallest one i think. id know better if i was looking at it and its snowing outside.
    No more GP 04 Impala SS Indy:
  3. #3 Re: few electrical problems
    Quincy, Mass
    i think if the grounds arent hooked up you wont get spark. however if they dont spark then they are usually the same current, either they are both grounds or both positive.
  4. #4 Re: few electrical problems
    Apr 2009
    stockton ca
    yea i marked all most everything but it was a month ago
    also my starter only has one small i know cause i couldnt find a small enough socket and cut the wire ill test for wich is a hot wire then thanks
  5. #5 Re: few electrical problems
    The two grounds are in the same loom and tied together. They hook to the trans stud with the ground cable.
    The starter. I recall the purple solenoid wire, and then on the large post is the battery cable and one other wire.
  6. #6 Re: few electrical problems
    Apr 2009
    stockton ca
    ok well today is the day either she fires up and purrs or i find a new line of work lol
  1. Major Electrical Problems
    By Lighty in forum General Tech Discussion
    Last Post: 12-13-2009, 01:46 AM
  2. Electrical!!!! HELP
    By gtpman in forum General Tech Discussion
    Last Post: 11-08-2009, 06:42 PM
  3. Electrical Problems 98 GTP
    By KawaFord in forum General Tech Discussion
    Last Post: 07-31-2009, 08:20 AM
  4. Electrical problems
    By Baumku in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-21-2009, 09:31 PM
  5. i think im having electrical problems...
    By 2000GTP in forum General Tech Discussion
    Last Post: 01-17-2009, 08:36 PM
