Thread: drivability "issue"
Results 1 to 17 of 17
  1. #1 drivability "issue"
    GT Level Member riceburner's Avatar
    Aug 2008
    denver, co
    so i got a ? for people real quick on drivability. when i turn the car on "cold start" it has a rough idle, and the low coolant light is on. after a min or so the idle smooths out and after about 4 min the low coolnt light goes out...? anyone haved any ideas? haha sometimes it will idle fine too i dont even know...
    '01 GTP mods: K&N intake, autolite 104's, drilled 180*, !u-bend, !EGR, ported s/c, polished heads and TB and a LOT more whine
    '99 firebird mods (1 of 6): LS1 swap, custom exhaust, LS6 IM, RA intake, and a few suspension parts
  2. #2 Re: drivability "issue"
    my car idles really really bad on a cold start, almost like it has a vacuum leak but it doesnt. never heard of the low coolant light for only a short period..your coolant full?
    either way if it doesnt idle bad when warm, it shouldnt be a driveability issue.
  3. #3 Re: drivability "issue"
    Moore, Oklahoma
    If your low coolant light is coming on you have one of two problems... Either you coolant is low and/or needs to be bled properly. OR You coolant sensor in your radiator is clogged with **** from dexcool. Remove, clean well and reinstall...
    Shawn W. Larsen
  4. #4 Re: drivability "issue"
    Aug 2008
    denver, co
    coolant level is as full as i can get it. let it run open for 5 min with a drilled therm filling till i would not take anymore...and i fouund out today that im throwing a cyl 4 misfire as well as all the egr codes from removing it....would the egr mess the engine up when removed and cause this misfire? i checked and am getting proper spark and injection pulse. engine seems to run ok stutters a bit under heavier throttle and has an idle around 700-800 prm...
  5. #5 Re: drivability "issue"
    Aug 2008
    denver, co
    ttt?...
  6. #6 Re: drivability "issue"
    Ummm...misfire means one of your spark plugs are bad...PROBABLY #4
    Get rid of that damned drilled T-Stat too...and just get a regular 180*...or 160* whatever you want. Is your EGR removed? If so You would need a block off and a deleted code from the PCM for it to run correctly...but I'd change the plugs and T-Stat first
  7. #7 Re: drivability "issue"
    Aug 2008
    denver, co
    the plugs were replaced with this last rebuild. maybe 6 hours on them?...how could it be fouled this fast?!? and whats wrong with a drilled stat? i personally like the idea...and how bad will the engine run till i can get it tuned out? and i have both side of the egr pluged off.
  8. #8 Re: drivability "issue"
    a drilled thermostat is always a good idea since it allows a little to seep by all the time which keeps cold coolant in the engine more. why would you want to switch to a normal one?
  9. #9 Re: drivability "issue"
    Aug 2008
    denver, co
    the drilled t-stat is staying.....back to the issue?... what would be some causes for a misfire?...and would removing the egr cause the engine to run rich and run funny?
  10. #10 Re: drivability "issue"
    the EGR is only active during cruising, so that takes that out of the loop unless youre misfiring while cruising.
    is it just a random misfire? mine seems to do it at idle all the time, but once i drive it is normal. i also havent changed my plugs in a while.
  11. #11 Re: drivability "issue"
    Aug 2008
    denver, co
    it did not say random misfire...
  12. #12 Re: drivability "issue"
    GT Level Member Clar2478's Avatar
    Nov 2008
    Idaho
    plug wires or coils
    Call me Brad
    '06 GT: Just a few mods here and there.
  13. #13 Re: drivability "issue"
  14. #14 Re: drivability "issue"
    Aug 2008
    denver, co
    well, the car cruises fine. its just at idle on a cold startup and at wot. at wot it seems to studder a lot and there is no power behind it. and if it were the coils wouldnt the entire 1-4 coil be messed up causing a misfire in two cly instead of just one?
  15. #15 Re: drivability "issue"
    May 2008
    McHenry IL
    no way the exact thing thats wrong with it is your lacking a spark from the flux capacitor go to autozone ask for fluz capacitor links. problem solved.
  16. #16 Re: drivability "issue"
    Aug 2008
    denver, co
    well i got a new flux capacitor on order from kalecoauto.com
    you pain in the butt! haha i will have money to get new links tommorrow when i get paid.
  17. #17 Re: drivability "issue"
    Aug 2008
    denver, co
    i put in the new link and there is still a code? does it need to be reset?...or will it continue throwing the code till it is fixed?
  1. "abs" and "trac off" lights staying on?
    By john9472 in forum Brakes/Suspension/Chassis
    Last Post: 12-03-2013, 09:38 PM
  2. "Inferno Appearance" or 06 "SE Appearance Package"
    By romande in forum Visual/Body Modifications
    Last Post: 04-02-2011, 12:56 PM
  3. "Extra Clips" in 4T65E Transmission Valve Body?
    By agrazela in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-30-2008, 03:17 PM
