Thread: Engine swap done, problems
Results 21 to 28 of 28
Threaded View
  1. #1 Engine swap done, problems
    Punta Gorda, FL
    OK I own a 2000 Pontiac Grand Prix GT with a L36. I bought an engine and trans from a 1998 Pontiac Grand Prix GTP.
    I swapped both in, engine and trans and are now having electrical issues. This is a run down of what the set up it. And yes everything is stock as far as I know.
    1998 L67 engine, with 1998 L67 Trans-HD
    1998 L67 engine wiring harness
    2000 L36 engine fuse box (When running with the 98 Fuse box it dies soon after you start it)
    2000 L36 inside harness (Swapped out BCM and DIC with the 1998 GTP)
    1998 L67 GTP PCM
    Front ABS are both not hooked up because we can't find the connectors. Its like there not on the harness.
    Everything else is stock 2000 GT stuff, fuel pump and such.
    This is the problems I am having.
    Speedo does not work
    Temp Gauge does not work
    Tachometer does work
    Alternator will stop charging the battery
    Weird problem with the Low coolant light. When in Park and Netrual its on, once you go into Reverse it goes off.
    2000 Pontiac Grand Prix GT (98' L67 engine/trans swap)
  1. Major Electrical Problems
    By Lighty in forum General Tech Discussion
    Last Post: 12-13-2009, 01:46 AM
  2. Major Problems - Need help, please
    By dellfire in forum Off Topic Discussion
    Last Post: 11-04-2009, 09:37 PM
  3. could a top swap on my n/a 3.8 v6 engine fix current problems?
    By GEMINIokc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-06-2009, 08:59 AM
  4. top swap problems
    By sickofsoyo in forum General Tech Discussion
    Last Post: 01-06-2009, 08:24 AM
  5. Major Problems Please Help
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 06-11-2008, 08:52 PM
