Had the alternator tested, siad it was fine. I came home and went over the entire circuit, everything has power that is supposed to have it. So the only thing left is the battery its self I guess. I don't have a tester to do a load test so I'm going to have to take it somewhere. Its a AcDelco battery with a 60 month warranty and its only a year old. So I'm not sure if the place would test it before they replace it or just replace it.
And i cheeked the oil dip stick yesterday and there where some bubbles on it meaning there water in there, so that says Head Gasket but can't a LIM thats not sealed right do the same thing?
Because when I start it up there is no smoke, no puff just a small steady steam out of it doesn't seem to get wrose either if you hit the gas.
Thanks for the help guys, hopefully soon I will get these problems worked out.
