Thread: Replaced LIM Car Wont Start
Results 1 to 20 of 25
  1. #1 Replaced LIM Car Wont Start
    Ontario
    Ok heres the deal guys......
    1) Car has been stuttering upon hard acceleration for months now...I drove to London the other week and when the car got really hot it just gave out I heard a clunk and the accelerator just dropped out but then would kick in for a bit then drop out again and again
    2) I managed to get the car started but at high revs it would hesitate and fart like crazy especially the hotter it got
    3) I pulled the throttle body off to see if it was caked but there was a ton of coolant in between the throttle body and the intake... Pontiac said it was probably the lower Intake gaskests
    4) I replaced the Lower Intake Gaskets, The Supercharger Gasket and cleaned all the coolant off of both
    STILL NO START!!!
    5) Replaced the Crankshaft sensor due to the stuttering probloems
    STILL NO START!!!!
    6) Checked the spark plugs which looked like crap so I replaced them. NO START!!!
    7) Pulled spark plugs to check for spark and they were just soaked with gas so i dried them off and have spark at all plugs.... Turned the engine with no plugs in to get crap out....Reinstalled plugs car sounds like its just about to start but just wont run
    STILL NO START
    I figured since the plugs are soaked in gas im getting fuel ANY IDEAS GUYS!!!! Im at my whitts end
    Thanks in advance
  2. #2 Re: Replaced LIM Car Wont Start
    Charles City, IA
    Check the ground for the ICM.
    SMGPFC Two Nipple General
  3. #3 Re: Replaced LIM Car Wont Start
    Ontario
    But If my ICM was bad I wouldnt be getting spark at all would I????
  4. #4 Re: Replaced LIM Car Wont Start
    SE Level Member ASCStinger's Avatar
    Jan 2009
    Rochester, NY
    the heads are probably toast, and overheating motor is an unhappy motor and the 3800 heads like to crack under normal operating conditions. You might as well pull the heads and check for piston damage while you're there, that clunk and loss of power you described worries me
  5. #5 Re: Replaced LIM Car Wont Start
    Ontario
    Well the Temp guage was just a little past a quarter......The clunk was more or less like the feeling of something giving out like whatever was causing the sputtering originally... I couldnt see any coolant in my oil but there was a ton in the throttle body and in the UIM and even after the LIM gasket repair i still had some spitting into the TB but it has now stopped.... I took the exhaust off at the manifold and it seems to be backfiring/farting so wouldnt that mean i have decent compression? Also today I sprayed Intake cleaner into it and it ran a little bit and quit????
  6. #6 Re: Replaced LIM Car Wont Start
    Wichita
    Bad: fueling, coils, MAF, TPS? Just throwin' some thigns out there.
  7. #7 Re: Replaced LIM Car Wont Start
    Ontario
    Im getting Spark and Fuel so that rules out bad fueling and coils...MAF was tested while running before LIM replace and was fine....Would TPS cause a no start??
  8. #8 Re: Replaced LIM Car Wont Start
    Wichita
    If the TB isn't letting air in your car won't run proper.
  9. #9 Re: Replaced LIM Car Wont Start
    Your plugs are soaked with water. Off to find last weeks thread.
    Here ya go. http://www.grandprixforums.net/f17/h...ked-21665.html Read the whole thing through and what you'll find is your probably just soaking the plugs over and over again. Wet plugs don't fire.
  10. #10 Re: Replaced LIM Car Wont Start
    Ontario
    Thanks for your help Bill Boost Ive tried pulling the plugs and cranking but I guess not enough...Ill try the syringe with the hose on it and try to suck it all out
  11. #11 Re: Replaced LIM Car Wont Start
    Ontario
    *****UPDATE**** Still getting coolant into my TB which in turn is dropping into my EGR stove pipe. When I take the pipe off it is filled with coolant....Any ideas guys???? Im letting the plugs and holes dry out as we speak put a syringe in the holes but could not draw anything out maybe its too short???
  12. #12 Re: Replaced LIM Car Wont Start
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    Do a compression test. Its the best place to start. Did you use RTV on your LIM or anything like that? Im thinking that your LIM gasket did not seal correctly. It sounds like the car started before you did the gasket swap, so I would think it should start afterwards unless something is not sealed correctly. A compression test will tell you if crap is getting into your cylinders.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  13. #13 Re: Replaced LIM Car Wont Start
    Ontario
    K car starts now!!!!! Now I have another problem...
    Whenever I start the car it runs for about 10 seconds then shuts off and it stalls right away if I touch the accelerator
  14. #14 Re: Replaced LIM Car Wont Start
    vacuum leak most likely...or the MAF is bad...unplug the MAF and see if it runs good...if it does then your MAF is shot.
  15. #15 Re: Replaced LIM Car Wont Start
    Ontario
    K so car is running now and not stalling... I took it for a spin and the thing started to overheat.....
    I take it back home, pop the hood and hit the throttle and isnt coolant pouring out of the throttle screen whenever i gove it alot of throttle wtf?? where is this coolant possibly coming from the intake is suppose to suck but when i throttle it blows coolant through the tb
    Now the symptoms for LIM failure that werent there when I fixed it are there????? Milky oil cap etc...I replaced the LIM with the new metal ones and the UIM gasket with a brand new gasket
  16. #16 Re: Replaced LIM Car Wont Start
    Wichita
    Quote Originally Posted by gprixster View Post
    Eew, you may as well get a new motor. Lets all pray you don't neeed one anyway.
  17. #17 Re: Replaced LIM Car Wont Start
    Feb 2008
    Houston
    You're going to get coolant in your oil during a LIM swap. You don't need a new motor, just tear it back down again. You obviously didn't get something to seal, print out a walk thru and follow it to a tee. Sometimes we tend to rush because we lose patience. I have been in your shoes, just take your time. Also do atleast 3 oil changes. You didn't use etc or anything on your LIM gaskets did you? Don't drive anymore until you fix the problem.
  18. #18 Re: Replaced LIM Car Wont Start
    Ontario
    Nah everything was done properly I just never tightened the TB before I fired it up so the coolant that runs under the TB must have got into the intake Stupid mistake didnt think anything of it...
    So at this point all I should have to do is clean out the TB reconnect it this time and do a few oil changes and it should be fine...Am i correct??
  19. #19 Re: Replaced LIM Car Wont Start
    Give that a try.
    BTW your car sounds like it's an L36 or NA motor. When you had the UIM off did you check to ensure the EGR area of the UIM was not cracked? Changing a gasket won't fix a UIM crack.
    It does sound like you've found the TB gasket leak issue though.
  20. #20 Re: Replaced LIM Car Wont Start
    Feb 2008
    Houston
    So what about the coolant in the oil? There is no way for the coolant to get in there unless you have blown head gaskets, LIM gasket failure, cracked head, or you didnt change the oil. You say everything was done properly yet youre posting having problems....none of us is perfect. Coolant leaking around the TB will just leak out or leak into the UIM and get burned up in the cylinder.
  1. Wont start
    By EmEaston24 in forum General Tech Discussion
    Last Post: 08-27-2009, 09:20 AM
  2. car wont start right away .
    By NEONNIGHT34609 in forum General Tech Discussion
    Last Post: 02-15-2009, 01:40 PM
  3. car wont start
    By 98gpgtp in forum General Tech Discussion
    Last Post: 10-22-2008, 05:26 PM
  4. Car wont start
    By 94GTRoyalty in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:57 PM
  5. Car wont start need help!!!!
    By drums4life0922 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2008, 09:34 AM
