Thread: Wont start
Results 1 to 14 of 14
EmEaston24 Wont start 08-22-2009, 05:17 PM
TorqueAutoMotiv Re: Wont start 08-22-2009, 10:14 PM
EmEaston24 Re: Wont start 08-23-2009, 01:20 AM
Liquifire Re: Wont start 08-23-2009, 07:33 AM
EmEaston24 Re: Wont start 08-23-2009, 09:40 AM
Liquifire Re: Wont start 08-23-2009, 01:43 PM
EmEaston24 Re: Wont start 08-23-2009, 03:07 PM
blueguy Re: Wont start 08-23-2009, 05:50 PM
GTPJOE90 Re: Wont start 08-23-2009, 07:26 PM
Bio248 Re: Wont start 08-23-2009, 07:53 PM
EmEaston24 Re: Wont start 08-25-2009, 08:50 PM
Liquifire Re: Wont start 08-25-2009, 09:58 PM
BillBoost37 Re: Wont start 08-26-2009, 06:15 AM
EmEaston24 Re: Wont start 08-27-2009, 09:20 AM
  1. #1 Wont start
    GT Level Member EmEaston24's Avatar
    Pittsburgh
    went to leave work today and my car didnt start, i think it might not be getting fuel or spark. the fuses look fine. 2nd time this happened to me lately, other times it will fire up fine, and sometimes its a little of a hard start. and input will help. thanks
  2. #2 Re: Wont start
    Apr 2009
    stockton ca
    can you hear the fuel pump, does it crank over, and so on whats it doing.
  3. #3 Re: Wont start
    Pittsburgh
    went to get it towed earlier and the tow truck driver listened to it then told me to try to start it again as he started hitting the bottom of my car with a metal bar. started right up. he said the fuel pump was going
  4. #4 Re: Wont start
    Wausau, WI
    if that is true........replace the fuel pump. What year make and model are you?
  5. #5 Re: Wont start
    Pittsburgh
    99 gtp. i belive you can get to them throu the trunk?
  6. #6 Re: Wont start
    Wausau, WI
    it could be the fuel pump relay as well.......they are kind of famous for going out on our cars.......did you try the bent tab for the relay? Or are you familiar with this...
  7. #7 Re: Wont start
    Pittsburgh
    i have not tried this... i actually forgot about this..
  8. #8 Re: Wont start
  9. #9 Re: Wont start
    May 2008
    McHenry IL
    mine pooped on me at school lucky i was in autos so we ordered the fuel pump it was like 240 then took the carpeting out in the trunk and theres a panel u uncrew it and yank the old 1 out put the new 1 in and your good to roll GP STYLE again haha
  10. #10 Re: Wont start
    sounds like a starter. do you have full power, turn the key to start and nothing happens? my car does it too. i hit the starter with a wrench and it works right away.
  11. #11 Re: Wont start
    Pittsburgh
    no im pretty positive its the fuel pump, it didnt start again and i hit the gas tank and it started up
  12. #12 Re: Wont start
    Wausau, WI
    Quote Originally Posted by EmEaston24 View Post
    makes sense......
  13. #13 Re: Wont start
    What our buddy ^^^^^ probably means is .. did the tow truck driver whack your car in the front or back. Front = starter, back = fuel pump.
    At first I read the whacked the car and it started as...beat the starter as well. However..if the driver told you fuel pump, then he better have been whacking the fuel tank.
  14. #14 Re: Wont start
    Pittsburgh
    yeah he was hitting the fuel tank for sure
  1. car wont start
    By ryangtp89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2009, 05:56 PM
  2. ran out of gas , now it wont start
    By jbon64 in forum General Tech Discussion
    Last Post: 12-25-2008, 02:27 PM
  3. car wont start
    By 98gpgtp in forum General Tech Discussion
    Last Post: 10-22-2008, 05:26 PM
  4. Car wont start need help!!!!
    By drums4life0922 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2008, 09:34 AM
  5. >??? dam still wont start
    By TMOTA503 in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-12-2008, 09:58 PM
