Thread: Replaced LIM Car Wont Start
Results 1 to 20 of 25
  1. #1 Re: Replaced LIM Car Wont Start
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    Do a compression test. Its the best place to start. Did you use RTV on your LIM or anything like that? Im thinking that your LIM gasket did not seal correctly. It sounds like the car started before you did the gasket swap, so I would think it should start afterwards unless something is not sealed correctly. A compression test will tell you if crap is getting into your cylinders.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  1. Wont start
    By EmEaston24 in forum General Tech Discussion
    Last Post: 08-27-2009, 09:20 AM
  2. car wont start right away .
    By NEONNIGHT34609 in forum General Tech Discussion
    Last Post: 02-15-2009, 01:40 PM
  3. car wont start
    By 98gpgtp in forum General Tech Discussion
    Last Post: 10-22-2008, 05:26 PM
  4. Car wont start
    By 94GTRoyalty in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:57 PM
  5. Car wont start need help!!!!
    By drums4life0922 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2008, 09:34 AM
