Thread: Cool Down to Power Up ?
Results 41 to 60 of 65
  1. #41 Re: Cool Down to Power Up ?
    in a house
    Quote Originally Posted by Murph9491 View Post
    so helppp hahha
    Your car needs lots. You make the rest of us GP owners look bad. Drive it off a cliff.
  2. #42 Re: Cool Down to Power Up ?
    Jan 2009
    Michigan
    well usually i just like to give people the benefit of the doubt. i like to think all the childish asshole comments are better left at cgp.
    however after seeing his cardomain page this appears to just be another kid that gives gp (particularly gtp) owners a bad name by just being a complete tool. guess i should have known when the thread went from, "how do i run cooler and increase voltage" to, "im settin the record".
  3. #43 Re: Cool Down to Power Up ?
    GT Level Member silvermistchick's Avatar
    Jan 2009
    Atlanta, GA
    what does a tstat exactly do for the engine
    well i was told by a very good tech that 160 degree t stats cause premature engine failure. read it and heard it several times. i do have a 180 but wont get anything lower
    see
    but leave the Thermostat alone unless you are building a dedicated 1/4 mile car (which I doubt). First of all the thermostat's rating is only the temperature that it opens, allowing full flow of coolant. So a 160 degree stat will open sooner, but the fan still won't turn on at that low a temperature; so you might run a little cooler on the highway where you have airflow, but not around town in stop and go driving.
    Second; if you modify the fan to get it to turn on sooner, you have now done nothing more than triumphantly thrown out 40 years of automotive technology and engineering advancements, and reverted right back to 1966 when lots of cars ran 160 degree thermostats. A modern car is designed to run normally at 200 - 230 degrees; it's more efficient, better for fuel economy, and will allow the engine to burn off condensation in the oil for longer engine life. The whole engine management system is designed around these operating temperatures; you can't alter one thing without affecting the entire system.
    Do yourself a favor and leave the correct thermostat in there and go enjoy your car!
    If you decide to do it anyway, take the old thermostat in to a good parts store (not a "McParts" store like Autozone, but rather a real parts store, i.e. NAPA or similar) and a good parts guy (or girl) can look it up by the dimensions even if it's not listed by application yet.
  4. #44 Re: Cool Down to Power Up ?
    ^^Are you kidding me? You can't be serious...serious? You go ahead and keep modding your car with the stock 195* T-Stat and I'll sit here and laugh. Getting a colder temp t-stat, such as a 180* is not going to affect your MPG's hardly at all, it keeps the motor running cooler, lowers KR levels...and yes...you can alter it. It is called TUNING. And you can't compare technology from 1966 to now. So many things are different...back then you had to have a cooler running car...for one thing oil was HORRIBLE and keeping it cool was the next best thing since it had to be changed every 1,000 miles or so.
    Also, you can get it to be cool around town AND on the highway. It is called turning the fans on early. I'm not sure who your very good tech is, but he's needing to be slapped.
  5. #45 Re: Cool Down to Power Up ?
    Banned - Busted For Scamming
    Feb 2009
    180 is good but 160 is too cold. You will cause premature bearing failure in your engine.
  6. #46 Re: Cool Down to Power Up ?
    Apr 2009
    Springfield,Va
    well ok ill explain myself again hahha , this 9 seconds stuff (FUTURE)will happen within the next few years , were planning everything out , but as for my current mod list , as seen directly above , these will be current and are experimenting with the car to see what it can and cant do , wanna beef it above stock and start small and not open a huge can of worms right now , seeing as its my daily driver , i think doing electrical and cooling and cam n such can give me a huge improvement above stock but i need some assistance from u tunign vets , bc u guys have experience , i have done alot of reading and have come along way , im converging from appearance mods and shoving performance in ... do u understand ? i want to start on a smaller scale , not my 20-30gs just yet , maybe a couple thous on these mods , so helppp hahha
    Dude learn how to use periods properly. Thats has to be the worlds longest run on sentence.
    Also x2 you look like a Dousch. Do you drive around blasting rap? Take a look in the mirror real quick.
  7. #47 Re: Cool Down to Power Up ?
    Donating Users PonchoDvr4Lfe's Avatar
    Feb 2008
    Kent, OH
    I am embarrassed to drive a GP knowing that car is out there somewhere... with a driver more blinged out than his car.
    PLEASE tell me where you got the Superman belt buckle!?!
    Seriously now, order a book, take a class or get a job changin oil and learn something about how your cars engine runs before you think you are going to start workin on that car!! For the cars sake (whats left of the decency of it), please!
    04' GP GTP Comp G, 08' G8 GT, 10' Camaro 2SS
  8. #48 Re: Cool Down to Power Up ?
    Jersey
    Quote Originally Posted by silvermistchick View Post
    see
    "Im ase certified A HAH, A HAH!"
    16' wrx sti- stock
  9. #49 Re: Cool Down to Power Up ?
    GXP Level Member
    Theworld
    I'm pretty sure this is someone on a new account messing with everyone, because there is no way it's real.
  10. #50 Re: Cool Down to Power Up ?
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    If that were so they would have responded to the bashing instead of fleeing in obvious embarrassment.
    2006 Grand Prix GXP
  11. #51 Re: Cool Down to Power Up ?
    Quote Originally Posted by KawaFord View Post
    Dead serious he was all up in my shiz on Car Domain too dude...FOR REAL. And it made no sense at all saying I race Camry's and my car looks like **** because it has no visual mods. I LOL'ed.
  12. #52 Re: Cool Down to Power Up ?
    Feb 2008
    Kent, OH
    Quote Originally Posted by DnaProdigy View Post
    X2!!
  13. #53 Re: Cool Down to Power Up ?
    Wausau, WI
    you ask him if he wanted to run one with you?
  14. #54 Re: Cool Down to Power Up ?
    Quote Originally Posted by Liquifire View Post
    Should I?
  15. #55 Re: Cool Down to Power Up ?
    Jul 2008
    New York
    Should I?
    Only if he will pay for the gas you will waste beating him.
    2006 Grand Prix GXP
  16. #56 Re: Cool Down to Power Up ?
    SE Level Member Planeboy18's Avatar
    Cleveland Ohio
    In the video it looks like he really knows his engine parts.... not!!!! It sounded like he said the tranny was on the passanger side of the car, at least it appeared that way to me. Hell, his car might even be twin charged. That alternator looking thing might actually be the turbo next to the super charger. Whoah!!!!! 9 second car here we come.
    04 GP GT (1st car now my G-Ma's):
    97 GP GT (GF's): "Project Pink Power"
    00 VW GTI VR6 (15*V6): Slow and Low, That is the Tempo
    91 VW GTI 8v: Big Plans
  17. #57 Re: Cool Down to Power Up ?
    Cleveland Ohio
    On one of his comments to another GP owner on cardomain he says that he's doing Audi and BMW foundation in his car. Anyone want to explain how the hell he did that? I'm a VW owner so i take offense to him trying to mimic German cars. I love GP's, but that's an abomination.
  18. #58 Re: Cool Down to Power Up ?
    Jul 2008
    New York
    Quote Originally Posted by Planeboy18 View Post
    Magic.
    2006 Grand Prix GXP
  19. #59 Re: Cool Down to Power Up ?
    Cleveland Ohio
    I guess having a car with Lambo doors means it's also based on any other european car.
  20. #60 Re: Cool Down to Power Up ?
    GTP Level Member Scimmia's Avatar
    QCA, IA
    2001 Buick Regal LS - Almost Stock
  1. cool...new guy
    By virility26 in forum Introductions/Noob Questions
    Last Post: 06-08-2009, 11:44 AM
  2. cool 4 anyone who has one......
    By boosting98 in forum Off Topic Discussion
    Last Post: 10-26-2008, 07:04 PM
  3. 04+ GP = Not Cool?
    By xerxescct in forum Off Topic Discussion
    Last Post: 10-13-2008, 04:50 PM
  4. This is really cool
    By s1795so2 in forum General Tech Discussion
    Last Post: 01-24-2008, 02:32 PM
  5. cool or not?
    By s1795so2 in forum Off Topic Discussion
    Last Post: 01-15-2008, 06:11 AM
