Thread: wont idle
Results 1 to 20 of 23
  1. #1 wont idle
    GT Level Member grand2000prixgtp's Avatar
    Grayslake
    just put my headers on went to start the car and it starts revs then dies. i can play with the gas to keep it running but it runs rough and it dies once i let off the gas any idea as what it could be?
    thanks
    2000 GTP silver four door, K&N cone filter, autolite 104 plugs, slp cat back, 3.4 pulley, zzp pcm, pacesetter headers, zzp stage 1 throttle body, ported superchrger, F body brakes. sold...
    2004 GTO all stock for now.
  2. #2 Re: wont idle
    Outer Space
    Check for vacuum leaks (ie. Lines not connected back) Also for exhaust leaks.
    What did you do with the EGR?
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: wont idle
    Grayslake
    Quote Originally Posted by Lawngoose View Post
    i cant tell if there is any exhaust leaks wont run long enough. took it off blocked it on the header and under the throttle body
  4. #4 Re: wont idle
    GT Level Member Swash's Avatar
    Excelsior Springs, MO
    Double check all connections that may have been knocked loose - MAF, vacuum lines, etc.
    -Swash
    I'm sorry, I can't hear you over the sound of how awesome I am...
    2004 IBM/Black/A4 GTO -- 1 of 273 - and the slowest
    2002 Galaxy Silver GTP - a few mods - sold
  5. #5 Re: wont idle
    When I did my rocker install all my car would do was crank over and over...turns out I never bolted down my main connection to the ICM...that bolt was just hanging out...double and triple check everything like Swash said.
  6. #6 Re: wont idle
    Grayslake
    i have look over everything ill look again tho
  7. #7 Re: wont idle
    Outer Space
    I had a similar problem when I couldnt get my EGR sealed right. I had a blockoff plate... ended up using a penny.. cause the plate was a PITA and leaked.
  8. #8 Re: wont idle
    Grayslake
    yea i use the penny's to
    the egr should be blocked off on the header and under the throttle body right
  9. #9 Re: wont idle
    Outer Space
    Correct, i have the egr opening on the LIM (under the TB, glued a penny with Copper RTV). Then the Exhaust egr outlet... has a penny jammed (bent in there) and I added copper RTV on top of it.
    Are you getting any codes?
    My car was pretty much undriveable when I had a leak at the LIM. Double check all vac lines, from TB to EVAP... under the snout of the S/C...
  10. #10 Re: wont idle
    Grayslake
    ok yea i got all the to glued up. i can find a vac leak but that is what i think it is cuz my boost gauge reads 0 when it trys to idle and reads 20 ish when i play with the gas.
  11. #11 Re: wont idle
    Outer Space
    Your boost gauge should read negative under idle.. Im not sure exactly the value (i dont have mine hooked up) ... double check those lines. Better yet remove them to see if that helps. Simplify the setup if possible.
    EDIT: From what i read... (correct me if im wrong guys, your should idle at 19in)
  12. #12 Re: wont idle
    It should read about -15 to -20 IIRC...
  13. #13 Re: wont idle
    Wausau, WI
    yes......this is accurate........sometimes as low as -23
  14. #14 Re: wont idle
    Grayslake
    i know before i did the headers it read somewhere around -20 but right now it reads 0 but if i give it gas it go to around - 20 but it still want s to die when i let off the gas. i dont know where else to look.
  15. #15 Re: wont idle
    Grayslake
    now if i disconnect the o2 or the air sensor it revs up to 3000 then down and dies. i have no clue what this could be/ anyone have an idea?
  16. #16 Re: wont idle
    Grayslake
    anyone?
  17. #17 Re: wont idle
    Grayslake
    any one have a vacuum line diagram?
  18. #18 Re: wont idle
    Wausau, WI
    can you get someone else to help you and just listen to try and find it?
  19. #19 Re: wont idle
    Outer Space
  20. #20 Re: wont idle
    ^^ Good deal...I couldn't find a good one...but that is for a '97 and they have a little different vacuum routing then the '98+ cars.
  1. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
  2. Car wont idle help!!!!!!!!
    By GINOSGTP in forum General Tech Discussion
    Last Post: 05-10-2009, 06:30 AM
  3. idle...HELPPP
    Last Post: 04-29-2009, 04:45 PM
  4. 3800 wont idle?
    By runn141 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-03-2008, 03:38 PM
  5. vacuum at idle?
    By grprx01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-23-2008, 06:37 PM
