Thread: wont idle
Results 1 to 20 of 23
  1. #1 Re: wont idle
    Outer Space
    Correct, i have the egr opening on the LIM (under the TB, glued a penny with Copper RTV). Then the Exhaust egr outlet... has a penny jammed (bent in there) and I added copper RTV on top of it.
    Are you getting any codes?
    My car was pretty much undriveable when I had a leak at the LIM. Double check all vac lines, from TB to EVAP... under the snout of the S/C...
    02 GTP 13.6 @ 100mph - SOLD
  2. #2 Re: wont idle
    GT Level Member grand2000prixgtp's Avatar
    Grayslake
    Quote Originally Posted by Lawngoose View Post
    ok yea i got all the to glued up. i can find a vac leak but that is what i think it is cuz my boost gauge reads 0 when it trys to idle and reads 20 ish when i play with the gas.
    2000 GTP silver four door, K&N cone filter, autolite 104 plugs, slp cat back, 3.4 pulley, zzp pcm, pacesetter headers, zzp stage 1 throttle body, ported superchrger, F body brakes. sold...
    2004 GTO all stock for now.
  1. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
  2. Car wont idle help!!!!!!!!
    By GINOSGTP in forum General Tech Discussion
    Last Post: 05-10-2009, 06:30 AM
  3. idle...HELPPP
    Last Post: 04-29-2009, 04:45 PM
  4. 3800 wont idle?
    By runn141 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-03-2008, 03:38 PM
  5. vacuum at idle?
    By grprx01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-23-2008, 06:37 PM
