Originally Posted by Lawngoose Check for vacuum leaks (ie. Lines not connected back) Also for exhaust leaks. What did you do with the EGR? i cant tell if there is any exhaust leaks wont run long enough. took it off blocked it on the header and under the throttle body
Forum Rules
