Thread: Do I need a gasket for a PLOG install?
Results 1 to 15 of 15
  1. #1 Do I need a gasket for a PLOG install?
    GT Level Member nickbuol's Avatar
    Apr 2008
    Marion, Iowa
    Going to get a new PLOG (ZZP made stainless steel one) but didn't know if I needed a gasket. They show only 1 gasket option on their web site, and I didn't know if that was for the front PLOG or a rear PEM. I called them, but it went to an answering service. Thanks!
  2. #2 Re: Do I need a gasket for a PLOG install?
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Reuse the stock piece.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  3. #3 Re: Do I need a gasket for a PLOG install?
    Outer Space
    I personally did not use one on the front (I dunno why, I didnt remember until I removed it.).
    But looking back, that probably wasnt the brightest idea.
    02 GTP 13.6 @ 100mph - SOLD
  4. #4 Re: Do I need a gasket for a PLOG install?
    Jersey
    id get a new gasket, but that's just me.
    16' wrx sti- stock
  5. #5 Re: Do I need a gasket for a PLOG install?
    Apr 2008
    Marion, Iowa
    Does anyone know if the gasket they show is for the front or for the rear, or are they the same gasket?
    -NVM. I see that I get the front and rear for that price, not just a single gasket.
  6. #6 Re: Do I need a gasket for a PLOG install?
    Banned - Busted For Scamming
    Feb 2009
    They are the same
  7. #7 Re: Do I need a gasket for a PLOG install?
    Apr 2008
    Marion, Iowa
    Thanks. I might as well pick one up then to ensure no leaks.
    Should I pick up new bolts for the PLOG or are the stock ones pretty solid? I hear that the crossover ones break, so I might grab 2 of them...
  8. #8 Re: Do I need a gasket for a PLOG install?
    Feb 2009
    Stockers are fine, the crossover bolts rust sometimes, but most times they come out fine, its a gamble.
  9. #9 Re: Do I need a gasket for a PLOG install?
    Apr 2008
    Marion, Iowa
    Maybe I'll see how well I can loosen the crossover bolts before ordering anything. If they aren't too bad, then great, if they give me trouble or look really bad, I'll spend the $7 and get 2 news ones on order.
  10. #10 Re: Do I need a gasket for a PLOG install?
    Jersey
    save yourself the troble and get new crossover and manifold bolts. Or be like me and crack an old rusted manifold bolt in your head
    16' wrx sti- stock
  11. #11 Re: Do I need a gasket for a PLOG install?
    Apr 2008
    Marion, Iowa
    If I got new manifold bolts for the front PLOG, which would they be? ZZP shows 3 kinds "A", "B", and "C"...
    Choices????
  12. #12 Re: Do I need a gasket for a PLOG install?
    Jan 1970
    Maquoketa, Iowa
    Reuse stock gaskets. Reuse stock manifold bolts.
  13. #13 Re: Do I need a gasket for a PLOG install?
    Charles City, IA
    ^ yup thats what I did on my header install. Make sure you have a long ratchet then when you start to have trouble hit the ratchet with your hand to kinda impact the bolt. You will break a lot less bolts that way.
    SMGPFC Two Nipple General
  14. #14 Re: Do I need a gasket for a PLOG install?
    Apr 2008
    Marion, Iowa
    Well, I went out with my ratchet, a 13mm socket, a long extension and a swivel attachment. I sprayed the crossover bolts with a short squirt of PB Blaster on each bolt, waited 5 minutes, and tried to loosen the bolts. It took all of about 5 seconds worth of effort per bolt to get them loosened up. It was actually quite easy. I am not sure of the ones on the engine will be as easy, but since they are supposed to be stronger, and they don't look any more rusted than the crossover bolts, I think I will be fine.
  15. #15 Re: Do I need a gasket for a PLOG install?
    Barksdale AFB, LA
    I wouldn't advise reusing the stock crossover bolts without applying anti-seize. I've seen reused bolts seize inside of 30 seconds. Yes I'm serious.
    2009 Subaru Impreza WRX STI
  1. Plog
    By 0LmtdGP3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-14-2009, 11:29 AM
