Thread: aeroforce question
Results 1 to 2 of 2
  1. #1 aeroforce question
    Jan 2009
    connecticut
    I need to scan for kr, and I was wondering if I get the aeroforce gauge could I just plug it into the OBD2 port and scan using it like a hand held or is there more to installing it and something has to be wired in order to use it?
    K & N cai / 3" downpipe / hi-flow cat / u-bend delete / 180 T-stat / ceramic coated plog & crossover / Overkill pcm / 3.5" pulley / zzp stage 1 TB / auto lite 104's / msd wires / poly mounts / slp front and rear sway bars / bmr trailing arms /
  2. #2 Re: aeroforce question
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    basically ya u just plug it in to the obd2 but there is a power, analog 1, and analog 2 harness u will have to plug in. just the power u have to hook up to accessory depending on if u want it to shut off automatically or if u want it to a switch. the analog 1 and 2 are for aeroforces other options like the a/f, and other things on there site. hope this helps
  1. aeroforce questions
    Last Post: 05-14-2009, 12:09 AM
  2. Aeroforce scan gauge question
    By 98SilvermistGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-10-2009, 06:47 PM
  3. aeroforce
    By TheOtherNick in forum Off Topic Discussion
    Last Post: 02-04-2009, 08:30 PM
  4. Aeroforce?
    By speedemongtp in forum General Tech Discussion
    Last Post: 11-07-2008, 07:30 PM
