Hi I just recently got done with my bottom swap and decided to drive to UF for the first time with the GTP and of course the car goes and embarrasses me. As I pulled into the parking garage my car dies and won't start back up. Needless to say my day was ruined as i missed a chem 2 final, and had to get my roommate to give me a rigged towing service with his tundra. I hear the fuel pump and I have plenty of fuel pressure. I just changed the plugs because it had a slight miss, but I was starting to think it was due to the rockers or computer since it still has a stock tune and 1.9 rockers and l26 bottom end, and the idle was still rough after redoing plugs. Anyways I checked a plug and it wasn't getting any spark when turning the motor over. Tomorrow when there is light I will try to work on it. I am almost certain non of the cylinders are firing since the motor spins freely and fast but I hear non combustion of any sort(no popping sound), and the car won't start. My guess is the ICM or a fuse since I was pulling fuses out a week ago to do a compression test. What do you guys think it could be. Does anything else control all the coils? The only other thing I can think of is the computer. Also what do you guys think about the rough idle? Do i just need a tune? I have everything done in my sig and its still a stock pcm. Thanks in advance.
