Thread: Topend chatter supercharger maybe...?
Results 1 to 17 of 17
  1. #1 Topend chatter supercharger maybe...?
    Apr 2009
    stockton ca
    So last night i bought a 98 gtp ive been looking for about 3 weeks and the one i found has high miles 150k+
    well theres a slight chatter from the supercharger i can feel it in the nose peice.
    now my ? is this what is the most likely cause of the this and how should i go about diagnosing and repair
    Im new to the gtp world but not cars so i can do the work myself..
    Thanks for any input of help
  2. #2 Re: Topend chatter supercharger maybe...?
    if you feel it in the snout it is probably a coupler or the snout bearings. most likely it is the coupler. does it sound like tumbling rocks?
  3. #3 Re: Topend chatter supercharger maybe...?
    Apr 2009
    stockton ca
    yea i can feel it on the snout and when the car shuts off it kind of rattle/grinds like rocks in a tumbler
    is the coupler or bearing a easy or harder thing to fix and will i need special tools
  4. #4 Re: Topend chatter supercharger maybe...?
    coupler is easy, you just have to take the blower apart. it connects the rotors to the snout shaft. just a circular piece of plastic with holes in it.
    bearings youll need a press. i wouldnt do them on your own unless you have a press..
  5. #5 Re: Topend chatter supercharger maybe...?
    Apr 2009
    stockton ca
    Im in auto tech classes right now and have about 500grand in tools at my disposal so the press isnt a problem
    Ive never puulled apart a charger before is it pretty straight forward
    and will i need to pull the pulley off to take it apart
  6. #6 Re: Topend chatter supercharger maybe...?
    really easy. yes, youll have to pull the pulley off, but then again, ive never taken any of the bearings out. i just buy a different snout/rotors/case instead since it costs about the same amount for me.
  7. #7 Re: Topend chatter supercharger maybe...?
    Banned - Busted For Scamming
    Feb 2009
    there is a write up here M90 Supercharger Disassembly
  8. #8 Re: Topend chatter supercharger maybe...?
    Apr 2009
    stockton ca
    thanks for the link helps alot looks pretty basic
  9. #9 Re: Topend chatter supercharger maybe...?
    Chicago
    I have the same problem on my 98 GTP. Just to clarify though, you HAVE to remove the pulley from the charger in order to simply open it and replace the coupler, or can it be left on? Only reason I ask is if the pulley needs to come off that means most likely investing in a pulley puller just to switch out a little coupler. Thanks for the help.
  10. #10 Re: Topend chatter supercharger maybe...?
    Barksdale AFB, LA
    The pulley stays on. You just have to slide the snout off.
    2009 Subaru Impreza WRX STI
  11. #11 Re: Topend chatter supercharger maybe...?
    the snout separates from the rotor pack which separates from the blower case.
    just a few bolts around the snout and then pull it apart.
  12. #12 Re: Topend chatter supercharger maybe...?
    A few long bolts...and if you are just replacing the coupler you only have to pull the snout off but be sure to drain the supercharger oil first...there is a small black piece in the front of the snout that can be removed with a alan wrench. Siphon the old S/C oil out (be sure to have 2 bottles of new S/C oil which you can get from a dealership) and remove the oil coupler and put the new one on. Best couplers IMO are the green ones from ZZ Performance.
  13. #13 Re: Topend chatter supercharger maybe...?
    Jul 2008
    Germantown, Maryland
    there are like 10 videos on youtube of the coupler change as well.... exaggeration but you get what I mean
  14. #14 Re: Topend chatter supercharger maybe...?
    Apr 2009
    stockton ca
    I just slaped a remaned supercharger off zzp on it and called it a day runs great now Ill probably rebuild the one i have if its not to messed up
  15. #15 Re: Topend chatter supercharger maybe...?
    Quote Originally Posted by wickedintent79 View Post
    Why? How much did that one cost you!?
  16. #16 Re: Topend chatter supercharger maybe...?
    Chicago
    Thanks for the info guys, look forward to a clatter free sounding engine.
  17. #17 Re: Topend chatter supercharger maybe...?
    Apr 2009
    stockton ca
    it was a used reman charger i think it was 250 but it works and sounds fine
  1. supercharger oil
    By handirifle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2009, 01:29 PM
  2. supercharger
    By cjim in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-25-2009, 07:30 PM
  3. Supercharger ?s
    By screamingreenmonster in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-12-2009, 10:21 AM
  4. Supercharger oil?
    By stewartj1998 in forum General Tech Discussion
    Last Post: 03-03-2009, 09:54 PM
  5. supercharger
    By ldyzluvdis06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2009, 08:53 PM
