and then i would be able to run my pulley fine with those?
headers open up the exhaust tremediously. kr is because the hot air cant get out of the motor quick enough.
yea im sure you would be pretty good then
ok thanks guys
for a nice, cheaper set of headers, i'd look at S&S.
PEMs or P-logs only do so much. For the price of those with a nice 3" DP, a set of decent headers could be had for not much more.
No matter what you'll need to scan.
Need to also think about the little things such as a tuned PCM, 180-tstat, and a set of colder plugs. The car probably needs some maintence too. Radiator flushed and refilled, tranny fluid + filter change, oil change, S/C oil change, fuel filter. Hoses and belts should be checked for any rot. It doesn't matter that the car has 15,000 miles on it, no matter what its still an 11 year old car and **** ages even if its not being used.
my car already has all of those things you just listed and i just recently changed hoses and fluids in everything
buy an aerooforce scanner and watch thatkr, then you'll be scared to run that 3.4...........and i like zzp, but i believe that is too optimistic. do a ubend delete and a 3" d/p. heck, that done and a 3.8 pulley will outrun that3.4 with no otrher mods(your k n only).![]()
i started with a top swap with a cam setup. ran it for a few days and spun a bearing. lesson learned on putting the car back together right (missing oil pump gear on the crank for about a minute of run time). then felt it would be easier to keep the boost under control with the l67 since i dont have a tuner and rely on my friends who do.
