Thread: Track Pulley Good Question!!
Results 1 to 12 of 12
  1. #1 Track Pulley Good Question!!
    Peachtree City GA
    So If I Have The Mods Listed On My Signature Minus Alki Injection, Is A 3.2 Pully Safe To Use At The Track With Race Gas, And Not Worry About Knocking? With My 'common' Set Up, How Small Of A Pulley Can I Use With How High An Octain Unleaded Race Fuel?
    And
    About How Much Psi Does Our Eaton Produce With A 3.2 Pulley In Lbs Of Boost?
  2. #2 Re: Track Pulley Good Question!!
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    IIRC Ideally you will gain 1 psi per tenth inch of a pulley drop. As far as what pulley you can run, only a scanner can answer that for you.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  3. #3 Re: Track Pulley Good Question!!
    Peachtree City GA
    I know one can't tell exactly for sure with out a scanner, BUT what is Generally speaking, safe at the track w/ what ocatain....
  4. #4 Re: Track Pulley Good Question!!
    Bastard Reptile's Avatar
    Kansas City, MO
    Nobody can safely tell you what you are able to run....with the amount of different types of scanners available now, theres absolutely no reason to not have one so that you can safely mod the car If you're going to put hundreds and potentially thousands of dollars into the car...spend the $40-$200 to get a good scanner to keep track of what's going on under the hood.
  5. #5 Re: Track Pulley Good Question!!
    my car knocks with a 3.4 still and i have way more mods than you.
  6. #6 Re: Track Pulley Good Question!!
    Kansas City, MO
    And there you have it. He knows what is going on.
  7. #7 Re: Track Pulley Good Question!!
    SE Level Member GTP SE's Avatar
    Ankeny, IA
    I agree with the scanner thats the only way to truly tell, I am able to run a 3.2 currently with 0 knock with the addition of 1.9's and a N* to my current sig mods on pump gas.
    2001 GTP Special Edition
    |ZZP PCM|Headers|Ported LIM and blower|3.2 / 3.4 pulley|1.9's|MSD wires|Drilled 180* T stat|3" ZZP Catback l
  8. #8 Re: Track Pulley Good Question!!
    Peachtree City GA
    Do you have any exhaust mods??
  9. #9 Re: Track Pulley Good Question!!
    Donating Users blowfishRus6's Avatar
    g.a.
    PEACHTREE!! i cant answer your question but you live close. i stay in carrollton and visit peachtree from time to time. what track are you going to?? do you go to friday night drags at atlanta motor speedway???
  10. #10 Re: Track Pulley Good Question!!
    Peachtree City GA
    i have only gone to the silver doller raceway in renyolds, once when i was stock, but im prob gonna go back sometime if still have my car! thats cool u live close , do u have a gtp also?
  11. #11 Re: Track Pulley Good Question!!
    g.a.
    yea i got an 04 comp g gtp. silver dollar is the only one i have been to also. intake and badly gaped plugs got me 14.6. they have friday night drags every friday i think. its only an 1/8 tho and its elimination. you lose and your out. 20 bucks to get in too.
  12. #12 Re: Track Pulley Good Question!!
    i have headers, rockers, home ported throttle body and blower, and i run a 3.4 right now. the slew of other tiny mods that i dont list help that much more too. i can run a 3.2, but it knocks just that much more and i dont want to blow it up before i put the intercooler on.
    im hoping with my SSIC i can run the 3.2 with 18*+ of timing. that will make for a fun ride.b
  1. GP's at the track
    By 4YOUTONV in forum Brakes/Suspension/Chassis
    Last Post: 05-05-2008, 04:34 AM
  2. I-70 Track meet in KC
    By Curtis in forum Shows and Events
    Last Post: 05-04-2008, 11:12 PM
  3. So I went to the track right?
    By TDCRacing in forum Off Topic Discussion
    Last Post: 04-05-2008, 11:57 AM
  4. F***** VHT at the track
    By TDCRacing in forum The Rant Forum
    Last Post: 04-01-2008, 11:28 AM
