Thread: Timing advance question
Results 1 to 20 of 33
  1. #1 Re: Timing advance question
    A worn motor mount of the headers rubbing can be picked up as knock.
    Did you have to bash the firewall to make the o2 sensor clear? That was a common rub spot with those headers.
    I do want to get a few facts in though. Per the high octane timing curve for a 2001 GTP file, the timing is as follows. ( I'm too lazy to screen shot this).
    In boost the cylinder airmass is going to at or above .80 to .90g just about all the time. With that said the timing from say 3,000rpm to 6,000rpm goes from 13 degrees down to 9 degrees. Timing slowly drops away as rpm rises.
    The computer also use a timing adder based on the commanded air fuel ratio. That value is 3 degrees at 11.7 AFR and 6 degrees at 10.7 AFR. So range of timing can vary from 9 to 19 degrees. Then you have intake air temps that could reduce the timing. Anything over 104 degrees remove 1 degree and once it's over 120 degrees it removes 2 degrees. So if it's really hot outside or the intake is pulling in really hot air it can reduce the timing.
    So timing can vary a little bit but a constant 9 degrees mean something, likely knock retard is pulling probably 5-6 degrees away.
  2. #2 Re: Timing advance question
    Mar 2019
    Nevada
    I didn’t bash my firewall I had that bung welded shut and a new 02 bung welded little farther down where there is no clearance issues.
    It is hot here in Vegas lol my IAT temps are often if not always above 104 lately. Once I’m cruising they are usually 10-15 degrees Above outside temps. And lately the outside temps when i drive are 95-110. It will be dropping to high 80’s next week so maybe I can get a wot pull in the morning. See if there’s any difference.
  1. Replies: 20
    Last Post: 11-26-2016, 07:26 PM
  2. 19° of Timing advance ?
    By suitercrew in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-24-2015, 08:53 AM
  3. Kr/ timing advance
    By duswickware in forum General Tech Discussion
    Last Post: 05-26-2014, 08:58 PM
  4. timing advance
    By hollas13 in forum General Tech Discussion
    Last Post: 07-22-2013, 10:46 AM
  5. Kr via timing advance?
    By 99PontiacGTP in forum General Tech Discussion
    Last Post: 02-06-2012, 12:33 PM
