Quote Originally Posted by 05GXPBeast View Post
Does the security light on the gauge cluster flash when you turn the key on? If the pass lock sensor failed then the security light will blink for about 10 minutes. After 10 minutes the light should shut off and you could try to start it. I had this issue once and I wasted time replacing my fuel filter and pump.
thats a security learn, theres no reason in for that to happen, unless he changed the pcm, and even then it would not crank. the key is 100% dead when you need a security learn. his cranks all the time. just dont fire up.
