I know this is a stretch but... Possible pass lock failure?
Does the security light on the gauge cluster flash when you turn the key on? If the pass lock sensor failed then the security light will blink for about 10 minutes. After 10 minutes the light should shut off and you could try to start it. I had this issue once and I wasted time replacing my fuel filter and pump.
I went out to start my car one day for work and it wouldnt fire, it just kept cranking. Once I found out it was the pass lock and I waited the 10 minutes it fired right up. And I never had it happen again after that. I hadnt done any work on the car recently either. Pass lock can and will cause a crank/no start condition if it acts up...
