Thread: boost bypass actuator
Results 1 to 2 of 2
  1. #1 boost bypass actuator
    Jul 2015
    indianapolis
    hey guys the middle barb was broke on the actuator and i know thats where i had one of the vacuum leaks, they had it superglued smfh. i know theres a way to remove the actuator from that shaft going into the supercharger i just cant figure how to angle it or whatever to remove it, does anyone have any tips or ideas to removing the BBA off of that shaft? thanks appreciate it
  2. #2 Re: boost bypass actuator
    Nov 2011
    NY
    You got to rotate it all the way around and then twist the vacuum actuator off once the key is aligned... It's not hard really, just make sure you take all the movement (range) and it'll go. Move the butterfly rod too...
  1. Check valve / pressure regulator to tune boost bypass actuator/solenoid?
    By wmorrison65 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-29-2016, 09:44 AM
  2. Boost a bit low, how to test the boost bypass solenoid & actuator?
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2014, 07:50 PM
  3. Boost Bypass Actuator
    By fri3dchick3n in forum General Grand Prix Discussion
    Last Post: 08-14-2013, 05:47 PM
  4. Supercharger bypass solenoid and bypass actuator question
    By 2004blackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2013, 04:46 PM
  5. Need help!~ with bypass valve boost actuator
    By dreama in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2012, 09:22 AM
