Thread: Boost a bit low, how to test the boost bypass solenoid & actuator?
Results 1 to 5 of 5
  1. #1 Boost a bit low, how to test the boost bypass solenoid & actuator?
    Cambridge, Ontario Canada
    Boost has been low for a while now in my opinion & can very from high's of 8.2 psi all the way up to last night 10.8 psi
    I unplugged the boost bypass solenoid but could only manage 3.2 psi lol, plugged the connector back in and managed to hit all time high of 10.8 last night. This morning, I can barely get to 9.
    How do I test the functionality of the solenoid or actuator?
    Also noticed that I don't hit maximum boost until very high in the RPM range...
    2005 E55 - stock
  2. #2 Re: Boost a bit low, how to test the boost bypass solenoid & actuator?
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    Well since it's a belt driven blower, aka supercharger, the higher the RPM's are, the faster the turbines or screws in the supercharger are going to spin. The faster those spin, the more boost it should create. So I would imagine at high RPM's is when you're going to see the most boost.
    When you unplugged the Boost Bypass Solenoid, did you just unplug the sensor? Or did you unplug the line coming from the snout side of the vacuum lines and plug it?
  3. #3 Re: Boost a bit low, how to test the boost bypass solenoid & actuator?
    Just the sensor. I thought our superchargers made max boost much earlier in the rpm range?
    2005 E55 - stock
  4. #4 Re: Boost a bit low, how to test the boost bypass solenoid & actuator?
    Oct 2011
    Toledo, OH
    Quote Originally Posted by Elite6 View Post
    Nope. Which is why pulley drops work.
    7"
  5. #5 Re: Boost a bit low, how to test the boost bypass solenoid & actuator?
    Aug 2011
    Michigan
    Not that I am aware of.
    In this picture, the blue line from the left of the Boost Bypass Solenoid should be unplugged from the sensor that I made in yellow and plugged off carefully using a bolt or screw or something. Same thing with the other small blue line I made going from the right of the sensor up to the Boost Bypass Actuator. Then you should see max boost and if that is the case, you can replace the Boost Bypass Solenoid
  1. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  2. Boost Bypass Actuator
    By fri3dchick3n in forum General Grand Prix Discussion
    Last Post: 08-14-2013, 05:47 PM
  3. Need help!~ with bypass valve boost actuator
    By dreama in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2012, 09:22 AM
  4. boost bypass valve solenoid wiring
    By 97RS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-24-2011, 09:59 PM
