Thread: Car running Lean, any advice?
Results 1 to 3 of 3
  1. #1 Car running Lean, any advice?
    May 2017
    North Carolina
    So my '99 Grand Prix Gtp is showing a code for a P0171B "Bank 1 System too lean" I have searched multiple threads to figure out what a potential cause/fix for that may be. I have already replaced the MAF (due to a previous problem which is now fixed) but this code showed up a few weeks later. Any ideas?
  2. #2 Re: Car running Lean, any advice?
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    It could be a number of things from a vacuum leak to a faulty o2 sensor and even misfiring. I would replace all the vacuum lines and check the egr tube at the intake and the exhaust manifold. also use your scanner to check you iac and ltft. Check out the vacuum tee under the supercharger snout. They are notorious for breaking.
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  3. #3 Re: Car running Lean, any advice?
    Jan 2017
    xx
    ^^^^ Completely agree. 9 times out of 10, that code is due to a vacuum leak. Start your search there.
  1. Running lean?
    By MrTube in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-05-2012, 01:05 PM
  2. Im running too lean?
    By dmahlikGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-13-2011, 12:36 PM
  3. Running lean
    By camarofan1974 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2011, 03:25 PM
  4. running lean?
    By Brennan7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2010, 10:07 AM
  5. Running Lean
    By duneking905 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2010, 02:06 AM
