Thread: Boost Bypass Actuator
Results 1 to 13 of 13
  1. #1 Boost Bypass Actuator
    GT Level Member fri3dchick3n's Avatar
    Alaska
    Well I noticed my boost once again didnt fully max out at wot. I unplugged one vacuum line from the bottom of my Boost Bypass Actuator or my BBV, took it for a ride and I get better boost. My fuel economy is garbage no matter how I drive. I check with the stealership for a new one. $269. ! That is just crazy, is it worth it? O'reillys wants $38 lol plus $30 freight. That doesnt seem right. Sounds like it will last 3 days.. I am unsure of what to do, any suggestions?
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180º Thermostat, Flipped Dog Bones
    Mercer, Pa
    What are you pricing the actuator or the solenoid valve. Zzp sells just the actuator for $50ish. You can post a wtb thread here and you can probable get one.
  3. #3 Re: Boost Bypass Actuator
    Alaska
    I am looking for an actuator, I checked ZZP and this is what I found. Eaton - EATON Bypass Valve #ETN-204103
    It looks right but says its for an Eaton blower, I am unsure, if that is what a stock 99 GTP has or is Eaton aftermarket?
  4. #4 Re: Boost Bypass Actuator
    Minnesota
    Quote Originally Posted by fri3dchick3n View Post
    Eaton is the stock blower.
  5. #5 Re: Boost Bypass Actuator
    Alaska
    the solenoid is what went bad, not the valve.
    Isnt that the solenoid in the link though?
    http://shop.zzperformance.com/store/...ass-Valve.aspx
    Are there any ZZP promotion codes I can use to get a discount?
  6. #6 Re: Boost Bypass Actuator
    Alaska
    Thanks. Now time to find out how many arms and/or legs it will take to get it to me
  7. #7 Re: Boost Bypass Actuator
  8. #8 Re: Boost Bypass Actuator
    that is the little mushroom shaped valve. they nearly never go bad.
    what went bad was the solenoid, which is the small box that the wiring harness is connected to. the solenoid got sticky and isnt letting the valve open/close how it should.
  9. #9 Re: Boost Bypass Actuator
    Alaska
    Oooh, thank you for clearing that up for me. Time to find that little box somewhere online meow
  10. #10 Re: Boost Bypass Actuator
    Portland Oregon
    You can grab one at the junkyard or run without it and get the code deleted. It's not a huge deal if you can scan. All it does is limit boost for traction control.
    Mercer, Pa
    I had a vacuum actuator go bad. Little tare in diaphragm you could see where the rod comes out.
    Best way to check is with a vacuum hand pump. Connect hose, pump it up and see if it holds. This works for solenoid valve as well.
    I have an extra actuator and a valve.
  12. #12 Re: Boost Bypass Actuator
    If you want/need either..pm me
  13. #13 Re: Boost Bypass Actuator
    Jul 2013
    San Bernardino,Ca
    [QUOTE=BillBoost37;773855]If you want/need either..pm me[/QUOTE
    I know this is really old but im still looking for a BBA, my actuator has a tare in the diaphragm and i think thats the source of my P0171 engine lean code.
    You have one?
  1. Need help!~ with bypass valve boost actuator
    By dreama in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2012, 09:22 AM
  2. boost bypass mod
    By mcsddd in forum General Tech Discussion
    Last Post: 08-19-2010, 07:50 PM
  3. Boost Bypass Valve is it the same as a BOV?
    By xsvtank in forum General Tech Discussion
    Last Post: 08-06-2010, 12:12 PM
  4. Boost Bypass mod
    By BADAZGTP in forum General Tech Discussion
    Last Post: 05-30-2008, 11:49 AM
  5. Boost Bypass Mod????
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2008, 11:04 AM
