Thread: Cam questions
Page 3 of 10 FirstFirst 12345 ... LastLast
Results 41 to 60 of 195
  1. #41 Re: Cam questions
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Yeah you need a machined oil pump cover and either 2 gaskets or a thicker one.
    Just curious, why would you run a single roller over a stock style chain? I think I've only ever seen one stock chain fail where tons of single rollers have.
    Well from everything I have read the single rollers are supposed to be made out of stronger metal and are better able to handle the higher spring pressure
    Sent from my LG-H901 using Tapatalk
  2. #42 Re: Cam questions
    Oct 2015
    Here's a picture of the cam paper that supposedly cam with the cam
  3. #43 Re: Cam questions
    May 2008
    Schuyler, NE
    They aren't. They are made to be nothing more than a stock replacement chain. Plus they eat the dampner quickly.
    Scroll down to prj' s post if you don't believe me.
    http://www.clubgp.com/newforum/tm.as...de=&s=#1923770
  4. #44 Re: Cam questions
    Oct 2015
    Everything looks on point except both the intake and exhaust lift are off by .002 and intake duration is off by 1 and exauat duration is off by 2
  5. #45 Re: Cam questions
    May 2008
    Schuyler, NE
  6. #46 Re: Cam questions
    May 2008
    Schuyler, NE
  7. #47 Re: Cam questions
    Oct 2015
    Well it's not that I don't believe I will just have to do more research. In the meantime if I go with a stock tensioner who makes the best one?
  8. #48 Re: Cam questions
    Antioch, IL
    single rollers are junk, stock or double or bust.
    2009 Challenger SRT8
    Expert at being gay.
  9. #49 Re: Cam questions
    May 2008
    Schuyler, NE
    Gm or cloyes.
  10. #50 Re: Cam questions
    Oct 2015
    Well ok then lol I'll probably just go stock then. First I'll research how much everything is for a double roller but if it's over 300$ I'm not gonna go through all the trouble
  11. #51 Re: Cam questions
    Antioch, IL
    double roller is cheap, have it machined shouldnt even cost over 200 done and done
  12. #52 Re: Cam questions
    Oct 2015
    Quote Originally Posted by ItHurtz View Post
    Ok please verify this. I thought all that was needed for a double roller was
    1. To remove balancer shaft and plug hole. Or just remove gear
    2. Install machined oil pump cover (zzp has for 55$)
    3. Install thick front cover gasket ( zzp has for 10$)
    That's it's right?
  13. #53 Re: Cam questions
    May 2008
    Schuyler, NE
    You should machine the crank sprocket and possibly the cam sprocket.
    http://www.clubgp.com/newforum/tm.as...key=&language=
  14. #54 Re: Cam questions
    Oct 2015
    Intense emailed me back and the short version is that a double roller would be overkill for 105s and that the singles were good setups but they did wear through the dampener faster so they recommended changing it every 50k if I went that route. In the end though they recommended I just buy a new stock chain since the 105s and s1x aren't anything crazy.
  15. #55 Re: Cam questions
    May 2008
    Schuyler, NE
    Yeah, 105's work great on a stock chain. The only reason you'd need a double roller is to get more power with a heavier spring.
  16. #56 Re: Cam questions
    Oct 2015
    Well I thought eventually about maybe adding some 1.7 rollers in which case maybe with the extra lift I'd want the double but meh that's probably not worth the money anyhow.
    Question is does anyone have a part number for a genuine gm chain? I found the cloyes one on rock auto but haven't found a gm one. I'm also topswapped so I have an l36 bottom end I'm assuming I'd still buy the l67 chain though right?
  17. #57 Re: Cam questions
    May 2008
    Schuyler, NE
    Yes, same chain.
    Stock rockers will actually make more power than 1.7 rollers.
  18. #58 Re: Cam questions
    Oct 2015
    Yes, same chain.
    Really why? The thing i like about the aftermarket is I currently have 1.9 yella terras and I **** you not their like half the weight of the stock rockers. Pretty crazy stuff. They will be for sale soon too!!
  19. #59 Re: Cam questions
    Oct 2016
    mm yella terras
    Sent from my LG-D851 using Tapatalk
  20. #60 Re: Cam questions
    May 2008
    Schuyler, NE
    Stock rockers will end up having more lift due to their design. That, and the moment of inertia on an aftermarket rocker is much larger, which has shown to negate any benefits of weight and the roller tip.
  1. Two questions
    By tomtom123 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-23-2014, 03:56 PM
  2. Window Tint Questions and Rear Speaker Questions
    By Wisconnie in forum General Grand Prix Discussion
    Last Post: 06-22-2013, 07:17 PM
  3. Replies: 2
    Last Post: 01-30-2012, 09:40 AM
  4. Few Questions :)
    By GrandPrixSE in forum General Tech Discussion
    Last Post: 06-06-2010, 08:20 AM
  5. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
