Thread: Cam questions
Page 2 of 10 FirstFirst 1234 ... LastLast
Results 21 to 40 of 195
  1. #21 Re: Cam questions
    Nov 2011
    NY
    Use Pac 105's...
    Dont need a double roller for 105's, BUT, while everything is open, why not, if you go heavier springs you're all set.
  2. #22 Re: Cam questions
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Quote Originally Posted by coolone View Post
    Use Pac 105's...
    What's the difference between crow 105s and Pac 105s?
    I just really didnt want to change springs, last time I changed the springs I had the head off so it was super easy work but changing them with the head on makes me very nervous
    Sent from my LG-H901 using Tapatalk
  3. #23 Re: Cam questions
    May 2008
    Schuyler, NE
    Quote Originally Posted by suitercrew View Post
    Thanks for talking me into man, I was hoping to not have to change springs but after more research l76 springs max at .520 lift which isn't even enough to run a vs cam. I'll probably go with the 105s though since that's what intense recommends for the s1x and since they will be easier on the chain. If I go single chain is the rollmaster or jp worth the extra money over a oem chain?
    If you aren't doing a double roller, stick with the stock style chain. The single rollers eat tensioners quickly.
  4. #24 Re: Cam questions
    Banned
    Oct 2016
    Carroll, Ohio
    Pull your #1 cyl plug and stick a long screwdriver or magnet in there, turn it over till you feel it stop up top.... Tdc
    Sent from my HTC6515LVW using Tapatalk
  5. #25 Re: Cam questions
    Banned
    Oct 2016
    Carroll, Ohio
    Replied to his question on page one, lol
  6. #26 Re: Cam questions
    Oct 2015
    Ok well the only question now is what cam to go with? S1x, xp, 3800 performance high energy? I don't have ported heads and I don't plan on it so ya. I really like the nic cam but everyone says it's really difficult to tune and although I have a tuner my skills using it are pretty beginner level so I don't think I want to mess with that.
  7. #27 Re: Cam questions
    Oct 2015
    I know a guy selling a brand new s1x for 280
  8. #28 Re: Cam questions
    Kemmerer, Wyoming
    you could also do an overkill spec cam
    http://www.getoverkilled.ca/3800tech.html
  9. #29 Re: Cam questions
    Oct 2015
    Quote Originally Posted by SgtMarshal View Post
    Well what do people recommend or have experience with?
  10. #30 Re: Cam questions
    Kemmerer, Wyoming
    I trust just about anything overkill says but I don't know anyone that has run this cam. If you look at his build recipe and his logic behind everything it makes perfect sense. I almost wish I had done his cam instead of the XP just because it is so much simpler and less parts to change.
  11. #31 Re: Cam questions
    May 2008
    Schuyler, NE
    Tuning a nic cam is no different than a xp or s1x.
    Nic will drop your mileage more than the xp or s1x. If that doesn't matter to you, and you will never intercool or e85 the car, then you might have the best luck with it.
    If you daily the car, will intercool it or e85, you should get the s1x or xp.
    As far as deciding between the two, their specs are almost identical, so whichever you get the best deal on.
  12. #32 Re: Cam questions
    Oct 2015
    Ya I just read through all his info and specs and both look like pretty good cams. They also only have .507 lift, maybe I don't have to change springs. Then again only leaving .013 margin for error is probably not smart lol. Also What's up with all the bad talk On the jp timing sets? Is that still a problem or after 7 years did they fix they're crap
  13. #33 Re: Cam questions
    Kemmerer, Wyoming
    Not a clue
  14. #34 Re: Cam questions
    Oct 2015
    Why the he'll are springs so expensive!
  15. #35 Re: Cam questions
    Oct 2015
    Are crow cam springs ****ty ****tyor why are they so much cheaper then comp or Pac?
  16. #36 Re: Cam questions
    May 2008
    Schuyler, NE
    Jp timing sets only applied to the double rollers. They had a bad batch and a lot of people lost motors. But I think rollmaster bought them out and fixed the problem.
  17. #37 Re: Cam questions
    Oct 2015
    Well I'll probably just end up going rollmaster. Also does anyone know who grinds intense cams. There's a guy selling an s1x cam and I just want to make sure it's real. The specs on the cam paper he sent me a pic of are a hair off, I'm not sure maybe that's just the tolerances? The cam he has is in a "cam motion" box
  18. #38 Re: Cam questions
    May 2008
    Schuyler, NE
    I believe comp does.
    And please tell me that you decided to go with the double roller.
  19. #39 Re: Cam questions
    Oct 2015
    That is undecided there's lots of people that run a single roller. I would run a double roller but I forgot what all was needed to do that, machined oil pump, extra thick gasket? Just a lot of extra $$$
  20. #40 Re: Cam questions
    May 2008
    Schuyler, NE
    Yeah you need a machined oil pump cover and either 2 gaskets or a thicker one.
    Just curious, why would you run a single roller over a stock style chain? I think I've only ever seen one stock chain fail where tons of single rollers have.
  1. Two questions
    By tomtom123 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-23-2014, 03:56 PM
  2. Window Tint Questions and Rear Speaker Questions
    By Wisconnie in forum General Grand Prix Discussion
    Last Post: 06-22-2013, 07:17 PM
  3. Replies: 2
    Last Post: 01-30-2012, 09:40 AM
  4. Few Questions :)
    By GrandPrixSE in forum General Tech Discussion
    Last Post: 06-06-2010, 08:20 AM
  5. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
