Thread: Gen v intercooler on gen 3?
Results 1 to 13 of 13
  1. #1 Gen v intercooler on gen 3?
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Hey guys there is a million threads on how to make a gen 3 intercooler work with a gen v but I have found nothing on if a gen v intercooler would work on a gen 3. As far as I can tell it should work fine right?
    Sent from my LG-H918 using Tapatalk
  2. #2 Re: Gen v intercooler on gen 3?
    hangover park IL
    I've only seen one guy do it.
    a very large amount of RTV under the gearbox was required to fill the gap as well as a week or so of time for to cure before you can start the car.
    I would imagine it would be a **** to do it and let it cure to find out you have a vacuum leak and have to do it all over again.
    It would work great if you could find a spacer flat plate that could fill the Gap and you would just need to use a Gen 5 gasket below and a gen 3 on the blower side
    ~James~ Psychotic Gearhead
  3. #3 Re: Gen v intercooler on gen 3?
    Oct 2015
    See I don't understand, why cant you just cut the lim to fit the gen v and call it a day? Why would it have a vac leak?
  4. #4 Re: Gen v intercooler on gen 3?
    hangover park IL
    the Gen 5 opening to the Gen 3 intake is no problem the problem is putting the Gen 3 blower onto a Gen 5 opening which leaves a gap at the snout end
  5. #5 Re: Gen v intercooler on gen 3?
    Nov 2011
    NY
    Just get the GenV SC, and thank me later...
    lol... The money you'd put in to make it work would be better spent on the slightly more efficient GenV. Just sayin...
  6. #6 Re: Gen v intercooler on gen 3?
    Oct 2015
    Thanks for clearing everything up for me guys!
  7. #7 Re: Gen v intercooler on gen 3?
    hangover park IL
    It wasn't really any money to get it to work it was just a crapload of our TV since dumbass forgot the supercharger oil for the Gen 5 and we had already put on the Gen 5 lower intake.... so we rigged it
  8. #8 Re: Gen v intercooler on gen 3?
    Oct 2015
    Ok quick question which do you think makes more power. S1x cam or a ssic and 1.9 roller rockers?
  9. #9 Re: Gen v intercooler on gen 3?
    Nov 2011
    NY
    Quote Originally Posted by suitercrew View Post
    Stock cam best you're gonna get is 300-320hp with added support on top of the SSIC and Rockers.
    S1X will get you the same, unless you change heads and full stack IC, etc., that could bring you to mid/high 300's.
    Again... There are no UNICORNS... Do your research, it's all out there!
  10. #10 Re: Gen v intercooler on gen 3?
    Oct 2015
    Quote Originally Posted by coolone View Post
    But I love unicorns!! But seriously I value your input. Thank you
  11. #11 Re: Gen v intercooler on gen 3?
    Dec 2012
    troll land
    Can be made to work with a gen 3 phenolic spacer if you can find one cheap. But I agree always genv lol
  12. #12 Re: Gen v intercooler on gen 3?
    Oct 2015
    Quote Originally Posted by l67ss View Post
    That's really smart. Didn't even think about that.
  13. #13 Re: Gen v intercooler on gen 3?
    Dec 2012
    troll land
    On this motor I knew I was gonna go gen v. Just wasn't sure when. I had gen v lim just no gen v. So I installed the gen v lim and actually made the spacer/adapter and ran a gen 3 on it. Made swapping to genv 8 months later a breeze. That and the fact that I planned on an ssic just hadn't got it yet so I also threw on a nodded rail at engine install. Was able to gen v swap without even pulling the rail lol
  1. Intercooler core, intercooler parts. Bonneville SSEi parts.
    By oldsman105 in forum For Sale - Parts
    Last Post: 03-23-2016, 04:59 PM
  2. Intercooler lower intake manifold without intercooler
    By GPChief in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2015, 02:35 PM
  3. dry ice intercooler
    By SgtMarshal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-08-2015, 04:04 AM
  4. Intercooler and more
    By Hawkman in forum For Sale - Parts
    Last Post: 11-15-2013, 12:28 PM
  5. zzp intercooler vs wbody store intercooler ?
    By boostedgtp13 in forum Off Topic Discussion
    Last Post: 05-04-2010, 02:40 AM
