Thread: Cam questions
Page 10 of 10 FirstFirst ... 8910
Results 181 to 195 of 195
  1. #181 Re: Cam questions
    Nov 2011
    NY
    Quote Originally Posted by suitercrew View Post
    Ok thanks guys. I've been all over the place second guessing my choice and if I should just sell all my cam stuff and go intercooler instead, it just seems like a cam would produce more power and I would really love a little lope but I wouldn't have to worry about destroying my engine installing an intercooler haha.
    Sent from my LG-H918 using Tapatalk
    This means you STILL don't have a plan... Generally not a good idea!
    You HAVE TO HAVE A PLAN! Plain and simple, otherwise you wind up all over the place like you are. Stop, take a deep breath or two. Go back, re-read everything you've read, then read it again. By then you'll have a decent idea of what you want to do. Then, make a list, start assembling parts, have everything ready for the build. Then read again, check, double check you have everything. Then just do it... Simple!
    Whatever it is... There's a map. There are no Unicorns to find on this platform as its all been done before. So whether it's a decent HP daily, or a beast track car with Max HP, there's a map/plan already out there for you to mimic and recreate!
  2. #182 Re: Cam questions
    May 2008
    Schuyler, NE
    Cams can cause problems too. Broken timing chains, broken springs, etc. Imo, the deeper you go into the motor, the greater the risk.
  3. #183 Re: Cam questions
    Nov 2011
    NY
    Cheap/Fast/Reliable
    Can't have but two at any one time, so choose wisely!
    Buy cheap, used, it might be fast, but reliability will suffer...
    Buy cheap but slow, it'll be more reliable...
    Want Fast and Reliable... Well, that's never cheap!
  4. #184 Re: Cam questions
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Yeah she doesn't like it when you go in dry!! Plenty of lube and ease it in.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  5. #185 Re: Cam questions
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Thanks for all your wisdom everyone! On a side note, when do mls head gaskets become recommended?
  6. #186 Re: Cam questions
    Kemmerer, Wyoming
    I went with fel-pro's, at one point I was intercooled and running the XP cam and the head gaskets were just fine. I do have head studs as well. I think MLS head gaskets are good if you want to raise the compression.
  7. #187 Re: Cam questions
    Oct 2015
    Quote Originally Posted by SgtMarshal View Post
    Well I'm topswapped and so I'm already running 9.4:1 I'm not sure if more compression is recommended for a boostes car. I'm just going to be right there to taking the heads off and so I'm debating doing a mild port job and changing the springs with the heads off and adding mls gaskets since ill be making probably around 300whp
  8. #188 Re: Cam questions
    Antioch, IL
    stick with stock
    2009 Challenger SRT8
    Expert at being gay.
  9. #189 Re: Cam questions
    Oct 2015
    Quote Originally Posted by ItHurtz View Post
    stick with stock
    Ok so stick with stock size? Would it still be a smart idea to switch over to mls gaskets at my level or is it unnecessary?
  10. #190 Re: Cam questions
    Kemmerer, Wyoming
    leave it alone, go with stock or fel-pro. mls are one more thing that can go wrong.
  11. #191 Re: Cam questions
    Oct 2015
    Aren't they supposed to be better though? I just replaced my head gaskets maybe 10k miles ago with felpros and copper spray when I topswapped.
  12. #192 Re: Cam questions
    Antioch, IL
    mls gaskets you need to have your heads and block smooth as a baby's butt and flat.
  13. #193 Re: Cam questions
    May 2008
    Schuyler, NE
    Mls gaskets suck on these motors. 50% of them seem like they never seal.
  14. #194 Re: Cam questions
    Oct 2015
    See, this is why I ask so many questions. I looked up quite a few threads regarding mls gaskets when I first considered them and I didnt see anyone mention this. Although I bet no one has tried zzps ones. As far as I know they have only been out about a month
  15. #195 Re: Cam questions
    SE Level Member The Reptile's Avatar
    May 2017
    Kansas City, MO
    Stock head gaskets, stock timing chain.
    I've never had a failure out of either one. I've had 2 aftermarket chains fail, and I'd never put another one back in. Side note, I've got a set of felpro head gaskets that we put on our turbo motor and bolted down, never ran. I'd make you a hell of a deal on them. LOL
  1. Two questions
    By tomtom123 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-23-2014, 03:56 PM
  2. Window Tint Questions and Rear Speaker Questions
    By Wisconnie in forum General Grand Prix Discussion
    Last Post: 06-22-2013, 07:17 PM
  3. Replies: 2
    Last Post: 01-30-2012, 09:40 AM
  4. Few Questions :)
    By GrandPrixSE in forum General Tech Discussion
    Last Post: 06-06-2010, 08:20 AM
  5. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
