Thread: Stock rebuild questions
Results 1 to 5 of 5
  1. #1 Stock rebuild questions
    SE Level Member 04palass's Avatar
    Oct 2012
    My Impala
    So I have a few questions. I have a 2004 Impala SS (L67) with 260k miles I am looking to freshen it up for a cross country drive.
    My original thought was to rebuild the engine in whole but after some research I've heard the bottom end of these can be very finakie to rebuild, so now the plan is a top end rebuild.
    My question is with a bottom end at 260k should I get new push rods or leave them? Or should i defure to my original plan and rebuild the whole thing?
    I'm looking for some guidance so anything would help. And this will be a 100% stock rebuild.
    Project 2004 Impala SS - Restored summer daily
    Project 2004 Indy SS - Winter daily
    Project SS #3- The beater
  2. #2 Re: Stock rebuild questions
    May 2008
    Schuyler, NE
    Just leave it alone. If it's running fine, don't mess with it.
  3. #3 Re: Stock rebuild questions
    Nov 2011
    NY
    260k, is it eating oil? Done a compression test, leak down and there's an issue? Leaking? Running rough? Why rebuild if there's no problems. General maintenance should do fine, all filters, fluids, check sensors like O2's, plugs, etc., cooling fine? AC? How's the Trans fluid look? Suspension?
    As mentioned, if it ain't broke don't fix it., but you can give it some TLC...
  4. #4 Re: Stock rebuild questions
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Control arms.
    Sent from my SM-G920P using Tapatalk
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  5. #5 Re: Stock rebuild questions
    Nov 2011
    NY
    Do a search on "pontiacbonnevilleclub.com illustrated rebuild of a L67" it's an old thread, but good nonetheless.
    theres a great write up... Although many will tell you it's easier and cheaper to bust by a JY engine should you need one. Just figured I'd share.
  1. 4T65E rebuild questions
    By 2000S80T6 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-15-2014, 08:49 AM
  2. 97 4T65E-HD rebuild and questions
    By Nchristopherson in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-08-2014, 01:42 PM
  3. l67 rebuild questions
    By ImpalaGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-31-2013, 02:42 PM
  4. Rebuild L67 questions
    By jsnyder49090 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2012, 10:18 PM
  5. rebuild questions
    By Toms04compg in forum General Tech Discussion
    Last Post: 06-15-2012, 09:23 AM
