260k, is it eating oil? Done a compression test, leak down and there's an issue? Leaking? Running rough? Why rebuild if there's no problems. General maintenance should do fine, all filters, fluids, check sensors like O2's, plugs, etc., cooling fine? AC? How's the Trans fluid look? Suspension?
As mentioned, if it ain't broke don't fix it., but you can give it some TLC...
