Ummm...misfire means one of your spark plugs are bad...PROBABLY #4
Get rid of that damned drilled T-Stat too...and just get a regular 180*...or 160* whatever you want. Is your EGR removed? If so You would need a block off and a deleted code from the PCM for it to run correctly...but I'd change the plugs and T-Stat first
