Thread: Car starts then as its about to Idle, car shuts off
Results 1 to 6 of 6
fasterthenu2000 Car starts then as its about... 02-05-2009, 02:49 PM
Bubweiser21 Re: Car starts then as its... 02-05-2009, 03:03 PM
Bio248 Re: Car starts then as its... 02-05-2009, 03:31 PM
fasterthenu2000 Re: Car starts then as its... 02-06-2009, 01:26 AM
JayAz Re: Car starts then as its... 02-06-2009, 03:49 AM
Bubweiser21 Re: Car starts then as its... 02-06-2009, 05:51 PM
  1. #1 Car starts then as its about to Idle, car shuts off
    SE Level Member fasterthenu2000's Avatar
    Jan 2009
    Syracuse, NY
    soo i have a 2000 GTP i went to go start my car today and move it and started i moved it about 2 feet then it died...ive tried starting multiple times after that and still wont stay running......i turn it on then right before its about to idle it turns off....any ideas of what could be causing this problem
  2. #2 Re: Car starts then as its about to Idle, car shuts off
    Feb 2009
    moundsville
    Sounds like a fuel issue.. I actually just replace the fuel pump in my GTP cause it would run until the car warmed up then just shut off and i'd have to wait a while and it would start again and run.. so far its good
  3. #3 Re: Car starts then as its about to Idle, car shuts off
  4. #4 Re: Car starts then as its about to Idle, car shuts off
    Jan 2009
    Syracuse, NY
    yea what im thinking it is a couple things...02 sensor,fuel filter, fuel pump, fuel pump resistor, CPS, or PCM..any other ideas of what it could be?
  5. #5 Re: Car starts then as its about to Idle, car shuts off
    May 2008
    I recently had a similar issue.
    Car would start, but then shut off. If I pressed on the gas pedal it would stay on, but the rpm would jump up/down. Was driveable, but had powerloss and eradic RPMs. The issue was a broken (top of housing fell apart when removed) MAP-Barometric Pressure Sensor.
    Replaced it ($68) and all is good.
  6. #6 Re: Car starts then as its about to Idle, car shuts off
    Feb 2009
    moundsville
    Had my car checked on a diagnostic an now its the MAF sensor. it will idle unless u rev it up when the RPMs drop it falls on its face
  1. Need some help folks, car starts, runs, then dies
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2010, 05:48 AM
  2. Car starts, bogs down and then stalls.
    By DnaProdigy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2009, 01:54 PM
  3. car sometimes starts/sometimes doesnt
    By 98gpgtp in forum General Tech Discussion
    Last Post: 11-05-2008, 12:29 AM
  4. Car never starts on first try but always on second try.
    By joshb227 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2008, 07:57 PM
