Thread: boost overload?
Results 1 to 6 of 6
  1. #1 boost overload?
    Sep 2015
    ohio
    when im driving my boost bar in my DIC is reading that my car is always using the supercharger. When im sitting still it reads the bar being half way used. Is there a problem with my DIC? Or is my supercharger actually always being used? And if my supercharger is always being used, will that effect my MPG because it will always be shoving more air through my engine therefore it will use more gas right?
  2. #2 Re: boost overload?
    Feb 2013
    37.295091, -121.930053
    yes more gas = bigger bang. but really i would start to look for the reason its show boost at an idle 1 reason might be vacuum leak.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: boost overload?
    Sep 2015
    ohio
    its like whenever im driving the bar is all over the place, i will have my car in cruise control on a road that isnt going up or down and the bar will be full and then 2 seconds later it will be like half way.
  4. #4 Re: boost overload?
    you might have a vac leak to the map sensor. its what reads your boost.
  5. #5 Re: boost overload?
    Kemmerer, Wyoming
    Check the vacuum line going to the map sensor. I've had the same thing happen and it was because the map sensor vacuum line that was disconnected
  6. #6 Re: boost overload?
    hangover park IL
    It's also possible that someone put a 1 bar map sensor on your supercharged car with a 2 bar bin file
    ~James~ Psychotic Gearhead
  1. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  2. Boost a bit low, how to test the boost bypass solenoid & actuator?
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2014, 07:50 PM
  3. Boost Bypass Valve is forcing boost at idle and reverse.
    By 94GrandPrixSE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2013, 09:37 PM
  4. Code Overload
    By Pogo D Klown in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-04-2009, 08:51 PM
