Thread: intake swap
Results 1 to 20 of 33
  1. #1 intake swap
    Jun 2015
    north carolina
    will an alum upper intake off of an 04 grand prix work on a 98 grand prix with the 3800 series 2 motor. I saw one at the junkyard and was just wondering. would be a lot better than the plastic one on my 98. if so is it as simple as just swapping them out or are there other things I will have to do?
  2. #2 Re: intake swap
    It won't change anything materially for performance or any gains. You would need a throttle body adapter plate to use it. Other than that, it's a pretty easy swap.
    If you are concerned about the failure that can happen from a plastic manifold leaking, pull the manifold and plug the coolant ports. I have a thread dedicated to modifiying LIM's that goes over it pretty well.
  3. #3 Re: intake swap
    Jun 2015
    north carolina
    ok thanks a lot man.
  4. #4 Re: intake swap
    Jun 2015
    north carolina
    anyway you could get me the link to the right thread? I'm having trouble finding it.
  5. #5 Re: intake swap
  6. #6 Re: intake swap
    Jun 2015
    north carolina
    thank you
  7. #7 Re: intake swap
    the stove pipe in the L36 and L26 LIMs are different diameters. you need to bore out the cavity in the L26 UIM for the L36 LIM stove pipe to fit.
  8. #8 Re: intake swap
    Or move it over...or if your car has ever had the UIM done then the stovepipe should have been changed at that time.
  9. #9 Re: intake swap
    Jun 2015
    north carolina
    what is the stove pipe?
  10. #10 Re: intake swap
    Apr 2015
    Columbus, OH
    The metal pipe that egr gasses go through. Between the two coolant ports you should block.
    Top Swapped 01 Imp
  11. #11 Re: intake swap
    in this pic, to the right of the t stat housing, you'll see a tube sticking up, thats for the egr. aka stove pipe, it goes up into the lim
    goes into the upper intake on the right side there.
  12. #12 Re: intake swap
    Jun 2015
    north carolina
    oh ok didn't know that's what it was called. I have some questions. I'm the same guy that posted about the white smoke and map sensor codes I can't get to go away. I changed the upper intake and gaskets for upper and lower intakes. should I have changed the stove pipe? also that little tube that snaps to the upper intake gasket is that the way the tube should be placed in the intake like in your photo. if so than I did it wrong. I put the curved end of the tube in the hole where the pcv and map sensor are located because that's where it looked like it would go. could that be what's causing me to get the map codes. this was the first time I've worked on one of these motors.
  13. #13 Re: intake swap
    thats the way it came off a running n/a engine i got for the bottom end. so my guess is thats how it should be. i touched nothing, but lifting it off the lim.
    when you did your lim gaskets was there coolant inside the lim?
    it look anything like this? http://www.grandprixforums.net/threa...hlight=failure this thread tells you why it happens talks about that stove pipe too and how it melts a hole int he upper intake. then it leaks.
    or the coolant ports leak. why its best to seal them up.
    if your was wet like that the egr stove pipe may be melted through and letting it leak still.
  14. #14 Re: intake swap
    Jun 2015
    north carolina
    yes it did but not that bad. I kinda feel like a dumb*** now because I got 2 different sizes of those stove pipes and for the life of me I couldn't figure out what they were for. I still have them in the garage. the instructions with the intake didn't tell me anything besides how to torque the bolts and where the map housing and the vac hose in the back attached. looks like I'm tearing back into it. the gaskets are new and have barely been run do you think I will have to replace them again or will they be ok. thanks for your help man.
  15. #15 Re: intake swap
    you can re use the gasket. check the upper intake for a hole in it like in bills thread there. if you find a hole you need a new upper intake pretty sure.
    sealing them two coolant ports should fix that issue tho and not require a new upper intake.
  16. #16 Re: intake swap
    The tube is wrong in the picture..
  17. #17 Re: intake swap
    Sure it is bill lol
  18. #18 Re: intake swap
    The bend should point up to the map sensor area. It actually fits up there. Then the tube runs down and parallel to the LIM. Hence it doesn't dump oil all in one runner. Instead it fills the all the areas of the manifold.
    This bend is upside down, but in the right area
    http://www.dormanproducts.com/p-3274...old&origin=YMM
  19. #19 Re: intake swap
    Jun 2015
    north carolina
    so I have it in right if I put the bend in the hole under the map sensor housing? or is the bend supposed to be in the middle of the intake pointing up?
  20. #20 Re: intake swap
    Oh the plastic tube, I'm pretty sure its just sitting in there.
  1. Ls1 intake swap
    By mrlogic1234 in forum 5.3L V8 (LS4)
    Last Post: 05-13-2014, 10:13 AM
  2. L36 to L26 Intake Swap
    By indygrandprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-29-2012, 09:31 PM
  3. Replies: 1
    Last Post: 12-31-2011, 04:55 PM
  4. L36 to L26 Intake Swap
    By jiminnc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-07-2010, 06:35 AM
  5. L36 to L26 intake swap
    By jiminnc in forum Engine
    Last Post: 08-01-2010, 01:12 PM
