oh ok didn't know that's what it was called. I have some questions. I'm the same guy that posted about the white smoke and map sensor codes I can't get to go away. I changed the upper intake and gaskets for upper and lower intakes. should I have changed the stove pipe? also that little tube that snaps to the upper intake gasket is that the way the tube should be placed in the intake like in your photo. if so than I did it wrong. I put the curved end of the tube in the hole where the pcv and map sensor are located because that's where it looked like it would go. could that be what's causing me to get the map codes. this was the first time I've worked on one of these motors.
