Thread: is there a easy way to replace the temperature sensor
Results 1 to 11 of 11
krsdadsps is there a easy way to... 12-07-2014, 07:08 PM
Scottydoggs Re: is there a easy way to... 12-07-2014, 07:10 PM
andesmint Re: is there a easy way to... 12-07-2014, 07:23 PM
krsdadsps Re: is there a easy way to... 12-07-2014, 07:27 PM
andesmint Re: is there a easy way to... 12-07-2014, 07:28 PM
Scottydoggs Re: is there a easy way to... 12-07-2014, 07:29 PM
krsdadsps Re: is there a easy way to... 12-07-2014, 07:32 PM
andesmint Re: is there a easy way to... 12-07-2014, 07:38 PM
08 gp lvr Re: is there a easy way to... 12-21-2014, 08:46 PM
08 gp lvr Re: is there a easy way to... 02-28-2015, 08:10 PM
99GT2dr Re: is there a easy way to... 02-28-2015, 08:45 PM
  1. #1 is there a easy way to replace the temperature sensor
    Nov 2014
    winston salem,nc
    so im about to replace my temperature sensor once again, i got another junk one. but damn is it a PITA with the intake on lol. i cant ever get them as tight as id want with the wrench. do you all have any tips on being able to do this with a little more ease
  2. #2 Re: is there a easy way to replace the temperature sensor
    nope, its in a crap area. open wrench would be your friend. and a ice cold engine.
  3. #3 Re: is there a easy way to replace the temperature sensor
    GT Level Member andesmint's Avatar
    Jun 2012
    Minot, Nd
    I used to use a crows foot with a 6" extension and a ratchet to get it broke loose/tightened all the way. Now I have zzp headers though so mines easy to get to
    2000 GT Mods: HAI, 10.5mm wires, rebuilt 60k motor, ZZP stainless headers, magnaflow mufflers, fresh paint job,L-67 top swap, Ported SC...
  4. #4 Re: is there a easy way to replace the temperature sensor
    Nov 2014
    winston salem,nc
    i may try the crows foot, as most of you all know ive went thru 4 bad new sensors so far. so im going to the junk yard to get one now. im tired of fighting the sensor in and out lol
  5. #5 Re: is there a easy way to replace the temperature sensor
    Jun 2012
    Minot, Nd
    I went through three of them before I got a good one
  6. #6 Re: is there a easy way to replace the temperature sensor
    if you can get a ratcheting box wrench on the sensor that would be the easiest way id think. its what i used to do my header install. as a socket just dont fit in there so well to all the bolts.
  7. #7 Re: is there a easy way to replace the temperature sensor
    Nov 2014
    winston salem,nc
    i got one from advance auto, auto zone, napa and through gm and got a acdelco and none want to work wright. i just tested the wires so i know thats not it. i cant belive how many of theses temp sensors are junk, antifreeze aint cheap its driving me crazy
  8. #8 Re: is there a easy way to replace the temperature sensor
    Jun 2012
    Minot, Nd
    Yeah I know what you mean. I can't believe how many of them are ****. Most people have to go through three or so to get a good one.
  9. #9 Re: is there a easy way to replace the temperature sensor
    SE Level Member 08 gp lvr's Avatar
    Nov 2011
    north bay, ontario
    Was just wondering what your symptoms were of a bad temp sensor? I think mine is about to go.
  10. #10 Re: is there a easy way to replace the temperature sensor
    Nov 2011
    north bay, ontario
    I know this is an older thread but this made my life easier and hopefully save someone else's sanity and rocker panel from a hammer lol. I cut the combination wrench to a little less than half of it and was able to work on it easily by pushing the rad hose down.
  11. #11 Re: is there a easy way to replace the temperature sensor
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    I used a deep 12 pt socket with a 3/8" ratchet. One click at a time, but went on fine. Forgot to put the damn thing back on the intake before reinstalling after doing the LIM gaskets.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  1. Can you replace worn buttons on '06 temperature control/DIC?
    By nickbuol in forum General Tech Discussion
    Last Post: 07-13-2017, 08:16 AM
  2. Easy Way To Replace Axel On A 04 GP non super charged
    By That1Guy1986 in forum Brakes/Suspension/Chassis
    Last Post: 07-29-2014, 11:20 AM
  3. Harness for coolant temperature sensor
    By Duffman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-16-2011, 07:13 PM
  4. How easy is it to replace a bad wheel bearing?
    By Bjm5295 in forum Tires & Wheels
    Last Post: 05-28-2010, 01:02 PM
  5. o-ring for temperature sensor?
    By nlinesk8s in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-04-2010, 04:06 PM
