Thread: Easy Way To Replace Axel On A 04 GP non super charged
Results 1 to 10 of 10
  1. #1 Easy Way To Replace Axel On A 04 GP non super charged
    Jul 2014
    Chesterfield,MI
    I went to replace my hub assembly and I noticed grease was every where from the cv boot so I figured I change the axel do I have to remove the ball joint and how hard is this process? Or can you just take the a arm down and slid it out?
  2. #2 Re: Easy Way To Replace Axel On A 04 GP non super charged
    Since you wanna be "that guy" eh, you coulda searched and found the write up. But I got this.
    http://www.grandprixforums.net/threa...ht=remove+axle
    Pretty much all you need to know, most of the tools and situations are the same for anything from 97-08. Be it a bonneville, regal or grand prix.
  3. #3 Re: Easy Way To Replace Axel On A 04 GP non super charged
    i like to pop the tie rod end out of the knuckle then push it out of the hub. some have said it will just come out with out popping the ball joint or tie rod.
    to get it out of the tranny, you need to push it in, so its off the C clip inside, then with a pry bar wedged in between the trans and axle. you pretty much have to kick the pry bar to pop it past the C clips thats holding it in.
    key is it cant be resting on the C clip or it wont come out. push it in, then pop it out.
  4. #4 Re: Easy Way To Replace Axel On A 04 GP non super charged
    Jul 2014
    Chesterfield,MI
    So after you pop the tie rod off what does that do?
  5. #5 Re: Easy Way To Replace Axel On A 04 GP non super charged
    Jul 2014
    Chesterfield,MI
    And if you take your ball joint off do you need a special tool to put it back in? These may be dumb questions but I'm not a mechanic!
  6. #6 Re: Easy Way To Replace Axel On A 04 GP non super charged
    The special tool is the pry bar.
    Push it back down and re-align with the hole the knuckle, then put the nut on and tighten it back down.
  7. #7 Re: Easy Way To Replace Axel On A 04 GP non super charged
    I have a special tool. Gearwrench 82248, it's the official axle removal tool for me and ... it is Scottdoggs approved!
  8. #8 Re: Easy Way To Replace Axel On A 04 GP non super charged
    Jul 2014
    Chesterfield,MI
    Well that was a job, ended up doing a ball joint tie rod axel and wheel bearing but I can't get the abs and traction control light off
  9. #9 Re: Easy Way To Replace Axel On A 04 GP non super charged
    If the scanner still says it's coming from that wheel, then inspect the wire harness. It might have to be replaced.
  10. #10 Re: Easy Way To Replace Axel On A 04 GP non super charged
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Mine broken on the part of the harness that run across the LCA, I pulled the loom back and could easily see where they broke off as the wire was just sitting in the loom
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  1. Need Help with my 01 grand prix gt 3.8l not super charged
    By sammie in forum General Tech Discussion
    Last Post: 12-24-2012, 10:56 PM
  2. gt none super charged....
    By Jacob Turrentine in forum General Tech Discussion
    Last Post: 05-09-2012, 05:28 AM
  3. 3.8l super charged tach loss
    By fritzie001 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2011, 12:41 PM
  4. super charged or not ?
    By 96gpse in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-09-2010, 11:42 AM
  5. Super charged/non-super charged question
    By ohgreatone32 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-04-2008, 10:31 PM
