Back in the summer I replaced the radiator on my wife's '99 Grand Prix. One of the items that I kept was a temp sensor near the battery, which is held on with a wire clip.
That sensor has been leaking lightly ever since, but it's gotten a lot worse with the cold weather.
When it was installed I used some plumbers teflon pipe dope to coat the o-rings, as they looked undersized for the cavity they fit in. Evidently that didn't do the trick.
Are those two square o-rings available separately? If not, has someone taken dimensions off those so I could order new from a vendor?
thanks,
