I have noticed that my car has a small leak on the passenger side of the engine block. (opposite from the thermostat). Has anyone had this problem? If so, any advice is welcome!
I'll check the water pump tomorrow. What are the coolant elbows?
Wow ~ thanks!
Could be a loose hose too, I had that problem a few weeks ago where I was mysteriously loosing coolant. Turns out the lower hose from the engine block had worked loose somehow. I loosened the screw, gave it a good shove, and tightened it again, problem solved.
But as others say, the most likely suspects is a water pump or a coolant elbow.
