Thread: Antifreeze on the passenger side of the engine block
Results 1 to 6 of 6
  1. #1 Antifreeze on the passenger side of the engine block
    Feb 2010
    Warren, Mi
    I have noticed that my car has a small leak on the passenger side of the engine block. (opposite from the thermostat). Has anyone had this problem? If so, any advice is welcome!
  2. #2 Re: Antifreeze on the passenger side of the engine block
    Commom leaks are coolant elbows or the water pump is leaking.
    Hard to say over the net with no pictures and I'm not there in person.
  3. #3 Re: Antifreeze on the passenger side of the engine block
    Feb 2010
    Warren, Mi
    I'll check the water pump tomorrow. What are the coolant elbows?
  4. #4 Re: Antifreeze on the passenger side of the engine block
    This, they tend to crack and leak or they just blow the **** out and dump coolant everywhere and the motor can overheat.
  5. #5 Re: Antifreeze on the passenger side of the engine block
    Feb 2010
    Warren, Mi
    Wow ~ thanks!
  6. #6 Re: Antifreeze on the passenger side of the engine block
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    Quote Originally Posted by nasa View Post
    Could be a loose hose too, I had that problem a few weeks ago where I was mysteriously loosing coolant. Turns out the lower hose from the engine block had worked loose somehow. I loosened the screw, gave it a good shove, and tightened it again, problem solved.
    But as others say, the most likely suspects is a water pump or a coolant elbow.
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  1. 2007 GP Base Engine Torque Mount Bracket Passenger Side
    By eetchickn in forum Wanted To Buy - Parts
    Last Post: 09-04-2013, 05:27 PM
  2. Replies: 0
    Last Post: 07-12-2013, 10:22 AM
  3. Leaking fuel from passenger side of engine!
    By 97gtpfreak in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2012, 12:10 PM
