Thread: Leaking fuel from passenger side of engine!
Results 1 to 7 of 7
  1. #1 Leaking fuel from passenger side of engine!
    Indianapolis, Indiana, United States
    As you all already know I'm a female and don't know much about cars lol! I'm leaking gas from passenger side of fuel rale I think :-/ I've been told it could be the gasket or broken fuel injector or broken fuel rale >:-/ I am wondering is there an o-ring in the fuel rale? Any help would be greatly appreciated! :-)
  2. #2 Re: Leaking fuel from passenger side of engine!
    St. Louis
    There are o-rings on both ends of the injectors, then o-rings on the fuel line connections where they meet the rails (where the black nylon line meets the metal rail). Which one is leaking? Worst case, take a pic and we can help.
  3. #3 Re: Leaking fuel from passenger side of engine!
    Sep 2011
    Copperas Cove, TEXAS
    Probably o-ring leak, but ford man is right, need pics.
  4. #4 Re: Leaking fuel from passenger side of engine!
    Ok thanks so much!!! And it'll be difficult to get a pic but I will try sat or sun. I can try an explain what I see I pop that black cover off the top of the motor between the alternator and the motor I can see the fuel injector and it's just barely leaking from around top to middle if that helps lol! Now my next question can you explain how in the world I could change the o-ring? Lol
  5. #5 Re: Leaking fuel from passenger side of engine!
    We can.. may also be able to get you pics.
  6. #6 Re: Leaking fuel from passenger side of engine!
    Mar 2012
    michigan
    follow the fuel rail around it has 4count them 4 10mm nuts on the lower parts of the rail around your supercharger when you take the nuts off they may fall mine did and they will land near the bottom of your injectors if u pull the rail before they are picked up they fall to the holes your injectors go in the heads but they are hard to get out if they fall in the holes and on the top ther should be a bolt that goes into your supercharger i beleive its a 13 mm deep well socket injectors just plug in i beleive
  7. #7 Re: Leaking fuel from passenger side of engine!
    I can't get the pic URL to load :-( go to photobucket and look up 97gtpfreak and u should find my album thanks again for y'alls help! ;-)
  1. A/C cold on passenger side and luke warm on drivers side
    By IFrees in forum General Tech Discussion
    Last Post: 05-14-2011, 05:06 PM
  2. coolant is still leaking around LIM at passenger side
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-27-2010, 10:11 PM
  3. Replies: 15
    Last Post: 09-19-2010, 09:53 AM
  4. Passenger side headlamp...
    By WayneG99 in forum General Tech Discussion
    Last Post: 09-25-2009, 06:30 AM
